Cannot connect to 2 wire.... It shows a strong signal
  • reneesarno05 May 31, 2010
    I use to get on-line no problem.. All of a sudden it isn't working for 2 days when it was working fine without a problem I didn't do anything
    different it says I am connected but I am not
  • 2,427 Answers
There is a button on the router .. push it,, then try to connect...... or press the resetr button behind the router then try to connect..
Posted on May 31, 2010
  • 6,487 Answers
This problem is usually related to a incorrect wireless security key that you use in connecting to your 2wire wireless router. Usually 2wire wireless router you can find the correct wep key or wireless key on the bottom of it on a sticker its compose of 10 character and if not that is usually the phone number that was assign to you by your DSL company. So try to disconnect from the wireless and reconnect again after you double check the wireless security key.
  • Mark Gil
    Mark Gil May 31, 2010
    If that;s the case try doing first a power cycle on your 2wire and computer, to do that first power off the 2wire then power off the computer wait for about 1 minute then power back on the 2 wire and when all lights are all solid power on the computer and then check if its connected wirelessly then try to o online.
Why does my tv keep freezing
I believe the antenna signal no strong enough ,Please checkout the connection between TV and antenna, If Panasonic TV will show you the signal quality in set up menu "10" mean good in 100%, If shows below "5" your antenna need attentions.
Aug 22, 2014 | Panasonic Televison & Video
Cannot access web
Make certain you have permission to connect. You may show a signal; but unless you are allowed to connect from the device to the wireless site; noting will happen. Make certain the system BIOs and Connecting software are up-to-date.
Dec 28, 2013 | Samsung Galaxy Tab 2 7.0
Authentication error
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Jul 12, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
I have my ps3 and Wii setup up and the show a strong signal from my router but won't connect
You will need to disable the Firewall on the Router
Step 1 : Connect Router - Computer (Wired )
Step 2 : Open RSP by typing 192.168.2.1 on the address bar of the internet Explorer
Step 3 : On the Left side Click on Firewall
Step 4 : Leave the Password Blank and click Submit
Step 5 : Disable the Firewall
Step 6 : Try Connecting
Jan 03, 2010 | Belkin (F5D8231-4) Wireless Router...
I use a dl 514 router. the computer shows a wireless connection and a strong signal but i'm not able to get online. now that I'm using a cable, it still shows a wireless connection with a strong signal.
Its quite likely that the router is not connected to your computer wirelessly. Which means, your wireless card is not picking up a IP address. I would suggest two thigns 1. In your wireless utlity , try to repair the connection. 2. Check if you have a static IP address. If you do, remove it.
Hope this helps
Thanks Ranjit
Sep 14, 2009 | D-Link DI 514 Wireless Router (DI-514)
Intermittent connection from router
Have you checked with your ISP on the strength and consistency of the signal before troubleshooting the router. If you're having problems with the wired connection, I would first try connecting directly to the modem to make sure you have a strong signal.
Let me know if you have a strong signal directly from the modem. We can troubleshoot the wireless router once we ensure the signal from the modem is good.
Thanks.
Aug 14, 2009 | Airlink Router
Can not connect but has strong signal
Try to check your accesspoint configration again. Is your wireless link Secured? if it is, reenter your network key and try to connect again. check your IP address to sure it is correct. Are you using authomatic addressing or is it manual,
go to your command prompt and type "ipcongif -all" on the computers that are wired and connected to the switch, view their settings and compare it with what you have on your laptop.
Apr 25, 2009 | Computers & Internet
Computer will not connect to wireless router
the antenna wire sounds pinched it is in the usually in the lid and can be found by looking in the hinge area
Look to see if it is kinked
LB
Sep 21, 2008 | ASUS Eee PC 900 16G Notebook
Check the wireless network card
try to reinstall the driver
Jul 27, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
