Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
It's clogged up at the base of the machine
We've been trying to take it apart to reach the clog but there's no apparent way to do that -- please help! Thanks
  • 40 Answers
http://www.espares.co.uk/datastore/ProductManuals/350256.pdf
See if the above link help you take it apart to clear the clog.
You can try calling their helpline at 866-MyDyson for further help
Posted on Sep 28, 2010
Hose not sucking at all
Depending on what vacuum you have there is likely a clog or restriction in the hose or one of the suction tubes leading to the hose.
Apr 07, 2015 | Vacuums
Dc59 pulsing
i am the same problem too.
Jun 16, 2014 | Dyson DC35 Handheld Vacuum
Dirt Devil Dual Cyclone - low suction, can't find clog, trying to take apart
Hi There
After the extensive checks you have carried out. May I respectfully suggest you check all your air filters, as a 'clogged up ' filter will produce the same kind of symptons as a blocked pipe. There is a very strong possibility that a filter on the machine is clogged and that's what is casing your problem
Apr 12, 2014 | Dirt Devil Reaction Twin Cyclone Upright...
Clogged
If you can find a way to reach the clog you may be able to remove it without tearing it apart. I use a flexible tool that comes from the auto parts store. It's made to reach down into tight spaces to retrieve a dropped part or nut. When you push the. Button on the handle it pushes little tines out the other end which I use. To grab the restriction to pull it out.
Mar 14, 2014 | Hoover Vacuums
Dirt Devil Ultra Vision vacuum- no suction?
Check for a clog at the neck of the "bag".
Sep 11, 2017 | Dirt Devil Vacuums
No suction
the hose can clog up insid where you cant see it my husband takes it off and runs water thru it to flush stuff out lets it dry then reconnects it
Sep 18, 2012 | Dirt Devil Featherlite Bagless Vacuum...
My vaccum is not sucking up barely anything and the cup is empty
In spite of it's advertising, it may actually be a clogged air passage. Remove the debris cup and reach into the air passage with a hooked wire to pick out any material. Do the same from the under side of the machine. The usual point of clog is where the upright and base components bend--there is a flexible hose there that tends to catch things large or sharp. Make sure the air exit filter is not plugged. Good luck!
Aug 11, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Clog in vaccuum
By Z, I think you mean it uses Z bags. There should be a screw and a nut ay the bottom of the handle asm. Take it out, then you can pull the handle off of the base asm. Then you can get to the tube and dig out the clog.
Jan 06, 2008 | Vacuums
Windsor Sensor Vacuum
Sounds like you have a clog, either in the hose, or the inlet down at the bottom. When there is a clog, the red light will come on and may also shut down to protect the motor.
Nov 19, 2007 | Vacuums
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
