Question about Mantis 2-Cycle Tiller
Transmission problem with Mantis 2-cycle tiller
While re-tilling my garden, the tines stopped rotating. When I stood the tiller on its kickstand and ran it, the tines would rotate, but stop again when entering the soil. There was no change in engine performance, no unusual sounds, and I didn't hit a rock.
I recently topped up the transmission housing with grease and examined the worm and gear-there was no visible wear.
I suspect a clutch problem. Can you tell me how to get the clutch assembly off the machine and examine it? Also, is there a manual available that I can download that would help me in repairing the Mantis? Thanks for information you can provide. **** Combe
  • 11,896 Answers
Www.littlewonder.com/12_engine_service_info/401702.pdf
That is a link to a manual.
It is likely the clutch which will have to be pulled off. If you can get your hands on a pulley puller, that would work.
Posted on May 31, 2010
MDT Tiller starts and runs but tines won't turn
-Won out drive or driven gears.
Good luck
Mai
Jun 28, 2014 | Mantis 2-Cycle Tiller
Tines bent
I would call mantis - the tines are covered by a lifetime warranty, and they should send you replacements for just S&H... not a bad price to pay for new tines.
Jan 28, 2013 | Mantis 2-Cycle Tiller
Just bought an older Mantis 2 cycle tiller. The tines engage when the tiller is started. Of course that makes it hard to start with the tines on the ground! I don't believe it was doing this when I...
if the idle is too high the tines wont stop due to the tiller tines are run by a "centrifuigual clutch" which means when you increase the throttle speed the tines will start to turn : there are 2 adjustments you can try,1) adjust the idle screw under the carburetor where the throttle adjustment and a triangle piece of metal touch(your throttle cable wire will be attached to this triangle) ,if the triangle and idle adjustment don't touch and there's a gap between these 2 pieces close the gap by adjusting the 10mm adjusting nut,this will correctly set the idle #2) adjust the idle adjustment screw talked about above till the tines dont turn with throttle set at idle or lowest speed setting
Mar 26, 2011 | Mantis 2-Cycle Tiller
My Mantis tiller is 9 or 10 years old. I've recently had the carburetor replaced but this year the tiller won't idle. The tines want to turn and you have to hold in the air to start it and move it to the...
My name is Dane and I am going to assist you in solving your problem.
You should have an idle screw adjustment on the carb to adjust the idle RPM. As you pull the trigger, watch on the carburetor for a small moving plate. The idle screw should touch that plate. Be very careful, and have someone hold the tiller and start it. Back off the screw just enough until the tines stop turning. I hope I've helped. If you found this reply useful, please leave me some THUMBS UP, if you feel I've deserved them. Thank you! Dane
Dec 06, 2010 | Mantis 2-Cycle Tiller
Tines turning, mantis 2 cycle tiller
sounds like a piston seizure. are you using correct oil and ratio. carb could be going lean and causing the cylinder to over heat, adjust high speed mixing screw and hope no damage has resulted.
Jun 30, 2010 | Mantis 2-Cycle Tiller
Mantis 2 cycle - tines lose power.
I had this problem today. Loosen the flange bolt. Pull the engine off and check that the hex end of the shaft is lining up with the clutch pad in the engine-that it seats properly. Then make sure the shaft is seated all the way into the worm gear and put the engine back on. You will probably have to wiggle the shaft until it seats into the clutch. Tighten the flange bolt when the engine is seated flush with the worm housing (with no gap). That's all I did and the power is back up. Hopefully you still have your manual with the parts blow-up. (page 29?) BTW, have you checked that the wormgear is greased?
Jul 05, 2009 | Mantis 2-Cycle Tiller
Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
May 02, 2009 | Honda Hmantis Mantis Garden Tiller with...
Mantis 2-Cycle Tiller Logo
376 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
