Question about GE WWRE5240D Top Load Washer
My washing machine is leaving a soapy residue with
My washing machine is leaving a soapy residue in the wash basin with clothes after it has completed the cycles. I also put in on the rinse setting with no clothes or soap in the machine and it and it still left a soapy residue.
My wife did say that she smelled a very faint burning smell the other day when both the washer and dryer were running but later the smell went away. Do you know what I need to do to fix it?
  • 15935 Answers
SOURCE: kenmore elite stops agitating after the rinse
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
SOURCE: shuts off in middle of cycle
I am having the same problem w/ our brand new front loader washer, it pauses constantly, and even when I can get the load to finish, I have to drain and spin atleast 3 x before I can even attempt to put in dryer, at this point it is taking me hours to do one load of laundry!!
Ugh-- Service man is coming tomorrow, so I will share what I learn...
Posted on Apr 23, 2008
SOURCE: stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Posted on Jan 06, 2009
  • 2920 Answers
SOURCE: burning smell from ge washing machine wpsr3100w1ww
either the belt or the motor are wearing out on it
Posted on Jan 08, 2009
  • 583 Answers
SOURCE: kenmore 80 series washer leaves soap residue on clothes no matter
check the link: below
Posted on Mar 12, 2009
Why does my machine not wash as good as it used to?
Water temp changed? Different detergent? Overloading enough to prevent proper agitation? All these can affect the performance. Also, if drainage is slow due to clog or weak pump, it might not rinse well, leaving soapy residue as well. Whirlpool pumps are pretty cheap and easy to change, usually, should that prove to be the source of your trouble. But look for simpler causes first.
Jun 27, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
How To Clean Silk
Hand Wash the item. Gently move the silk fabric around in the soapy water. Rub stains with your fingers or a sponge to clean them. Pour the water out when finished washing your garment.
Rinse the silk garment in a vinegar solution. White vinegar removes soap, restores shine and softens silk. Fill the basin with cold rinse water. Add 1/4 c. (50 ml) white vinegar. Gently move the garment around in the water to thoroughly rinse it. Empty the basin again.
Rinse the item in cold water. Add cold water to the basin. Rinse the silk item a second time in a basin of fresh, cold water. Turn the garment over and around to ensure it is completely rinsed and free of soap.
Sep 16, 2013 | Sewing Machines
My GE washer is leaving a brown oily residue inside the drum after washes.
I amj thinking that you use soap powder in your washing machine. If that is the case what you are expericing is the accumulated powder residue under the agitator breaking away and marking the clothes. Re move the agitator and clead all the gunk out of the machine including a water recycling(saver ) hoses. Washing powder is 90% clay that is used to carry the active ingredaient and is never completely flushed in the rinse cycle. Ity also cause a deteriation of the hoses and pumpseal. When you have cleaned out the machine I recommend you only use liquid detergents as they are more effective and don't leave the residue.
Mar 11, 2013 | Washing Machines
We have an Aquasmart top loader and our clothes, mainly dark items, are being covered by a scum after washing. We have put the machine through the clean cycle, but this has not made any difference.
I have found with my aquasmart that if you use the 'high efficiency' the water does not cover the clothes sufficiently which is why the soap residue (noticeable more on dark clothes) is visible. I don't use high efficiency. even on conventional sometimes I still have to check that the water level is high enough. Also **use only liquid, low sudsing detergent and do not put it on the clothes-use the dispenser only. As for my machine... Time for the repair man to check the sensing I think
WC Gold Coast
Aug 29, 2010 | Fisher and Paykel Washing Machines
My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang meny close can trap the dry stuf.
Jan 25, 2010 | Maytag PAV2300 Top Load Washer
My washing machine is leaving small bits of black
FIXYA has no way of knowing what they are or where they come from .we have no field techs . suggest you call a repair service
Oct 26, 2017 | GE Profile WPRE6100G Top Load Washer
We've owned this washing machine for r+ years and it has been making our clothes smell awful--in fact, the machine itself smells awful. I've tried cleaning the basin with a bleach solution and I even ran...
By my experience on Washer Machines, I would say that the problem are bacteria and mildew growing in the machine, not exactly in the drain or drum from the machine. Mildew can grow everywhere.
Oh, by the way, don't even think about bypassing any sensor from your machine. You don't want to wake up tomorrow and find a pool in your house, right?
To kill mildew and bacteria you may want to try some simple solutions:
* Keep the lid up between washes so that bacteria and mildew won't grow in it. Pour a bottle of vinegar in hot water and run it though the machine on a heavy load wash. When it is finished, leave the lid up.
* Didn't help? then pour a box of baking soda in it and running it with hot water cycle. Try running it without clothes.
... I mean, Run the washer machine without clothes inside. (Oh my gosh, I should go to bed, it's too late for giving advice on FixYa)
* If the smell continues Pour a big bottle of peroxide hydrogen (the 3% one from the drug store) and run a heavy load wash. Be sure not to use good clothes, it will get white. if that does not work, u may have a more serious problem. Perhaps the machine needs to receive maintenance and spray some peroxide hydrogen where the mildew is growing.
Also, You can try a commercial product for this kind of issue:
Some people says that it works when everything else fails.
Nov 08, 2009 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Put washing powder in tray ,machine doing wash but leaving large residue of powder
Don't put the powder in the tray. Select you wash cycle, let the water run into the washing machine, then add the powder.The powder should dissolve before you put your clothes inside the machine. Let the washing machine fill up to almost half way and add clothes. This should stop the clothes from getting the residue powder on it.
Mar 23, 2009 | Whirlpool Washing Machines
My washing machine is leaving little residue on all my clothes after a complete wash, What are they? and how do you get rid of it, the washing machine is not yet a year old
Describe the residue. If it's oily (black, dk green) then the seal is out of the tranny and oil is getting into the tub. Dry cleaning is best for oil based stains. Liquid dish detergent is good also. On white it is tough to remove. Your washer will need a new transmission or replacing.
If it is powdery I'd guess a soap buildup, especially if you've recently changed detergents. The new detergent is breaking up the old soap scum in the outer drum and it is redepositing onto your clothes. This should wash out/off.
Tip: If it's a soap residue, fill washer full without clothes with hot water. Add 1 gallon white vinegar and more hot water until the unit if as full as possible. Agitate 15 minutes and drain. Rinse with a full level and drain.
Jan 24, 2009 | Samsung SW62ASP Top Load Washer
GE WWRE5240D Top Load Washer Logo
255 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
