This is a Visual C# program question. Console app. Windows 7 32-bit developer platform. Visual Studio 2010 Console.Beep() does not work. My system has sound, as I can play videos or music without problems. For some reason, I just can't figure out why Console.Beep() does not work. Any ideas? Thanks.
  • Webbiz Jun 02, 2010
    Windows 7 Ultimate 32-bit
    Visual Studio 2010 C#
    Console App
    Speaker verified works by beeping when computer is turned on and visual inspection.
    Code Console.Beep() does not cause the computer to beep. Even with duration and freq as parameters it does not make a sound.
    Any ideas?
    President:
  • 1,902 Answers
// This example demonstrates the Console.Beep() method.
using System;
class Sample
public static void Main(String[] args)
int x = 0;
if ((args.Length == 1) &&
(Int32.TryParse(args[0], out x) == true) &&
((x >= 1) && (x <= 9)))
for (int i = 1; i <= x; i++)
Console.WriteLine("Beep number {0}.", i);
Console.Beep();
else
Console.WriteLine("Usage: Enter the number of times (between 1 and 9) to beep.");
This example produces the following results:
>beep
>beep 9
Beep number 1.
Beep number 2.
Beep number 3.
Beep number 4.
Beep number 5.
Beep number 6.
Beep number 7.
Beep number 8.
Beep number 9.
If you do not tell it to beep and where then you are not going to get anything to beep at all. Please let me know if this is of any assistance or if you need more
Posted on Jun 02, 2010
  • 4 more comments
  • Jeremy Reddick
    Jeremy Reddick Jun 02, 2010
    I would have to see your code to tell you what the problem is. I believe that you are most likely missing a line somewhere or a line fault. I would triple check your works and make sure that all tags are in place
    Hello.
    Appreciate your response.
    I copied your code and pasted it in a new Console app.
    It's not complete. When you run the code, it will go directly to the Console.WriteLine("Usage: Enter the number of times (between 1 and 9) to beep.") and then exit the console.
    Console.ReadLine() should follow the request for a number.
    I changed the code to just run the loop 9 times.
    class Sample
    int x = 9;
    Console.Beep();
    Console.ReadLine();
    It prints out Beep Number (number), but no 'sound' of a beep.
    Something is amiss and it does not seem to be the code. I'm suspecting something with the OS. ??
  • Jeremy Reddick
    That was going to be my next comment to you if there was nothing working. That was just a mock code I do no use it for anything but to show people the layout. What OS are you using? You may need to make it work with that one
    Windows 7 Ultimate (was Professional when I first tried to make it work. Same issue.)
  • Jeremy Reddick
    I have noticed that Windows 7 has had some bugs in regards to working with the C+. I just did a google search and here are some great links that I think will help you fix your problem. I had the same issue as you did when I was building a program for my step father. I know that there are ways around it, but it was a struggle to get it there.
    http://www.google.com/search?hl=en&c...
    Hi.
    I'm working in C#, not C++. And I did do a major search before posting the question here. Could not find a solution.
    thx
  • 2,427 Answers
Try Console.Beep(5000,12);,, specify the frequency,, and duration... also checl your mainboard ,, it has a small spraker thats attached to the board for this beep,, if you dont have one it wont beep.. its connected directly to the mb,, its not the same for your audio speakers..
Posted on May 31, 2010
  • 1 more comment
  • Webbiz Jun 01, 2010
    Thanks Darklord for taking the question.
    The speaker is on the case and it beeps when the computer is turned on. For kicks I opened the case anyway and verified it was there and wired correctly to the motherboard.
    In code, I had tried the freq and duration settings prior to asking the question. That's what is puzzling me. No errors in the code. Compiles fine, and the lines of code before and after the Console.Beep are executed, so it isn't being skipped.
    Unfortunately, no beep.
  • Rishi Roshan Ali Jun 03, 2010
    hmmmm.. ok right click computer and click properties,, click hardware then device manager or just device manager..
    look for something highlighted in yellow.. I got a feeling the Chipset drivers need updating... thats the only other thing that can cause this... OH an make sure u compile your code in release mode and not debug mode.. and run it from the bin directory.. it wont beep if u run it from vs studio..
    compile it in release form,, and go to your project folder and into the bin directory and run it from there look in the release folder..
  • Webbiz Jun 03, 2010
    Well, thanks for trying. But it appears to be an unsolvable issue.
    No yellow highlighted items in Device Manager. All working okay.
    Compiled code and ran from Release folder. Silent still.
    Here is the code I used.
    namespace ConsoleApplication5
    class Sample
    int x = 9;
    Console.Beep();
    Console.ReadLine();
    Writes "Beep number ..." 1 to 9, but does not beep.
    And I also changed it to Console.Beep(5000, 2000), but it only prints out the "Beep Number..." lines slower and no sound still.
    Strange. The speaker beeps when I turn on the computer each morning. So I know that it works. Just do not get it.
    Thanks.
Which exam can I take for a Microsoft .NET certification?
Microsoft .NET Framework serves as an exquisite platform featuring a common language architecture allowing application developers to build business-specific software solutions for widely used OS and devices, including iOS, Android, and Windows.
Developer and programming skills are skyrocketing and will continue to soar high. Achieving a developer certification can help you keep an edge in the market by making you stand out among your peers.
It is recommended to take up following Microsoft Certification exams to accelerate your career as .Net Developer:
    ·70-486: Developing ASP.NET MVC Web Applications
    ·70-497: Software Testing with Visual Studio
    ·70-498: Delivering Continuous Value with Visual Studio Application Lifecycle Management
    ·70-480: Programming in HTML5 with JavaScript and CSS3
    ·ALM Solutions Using TFS Visual Studio 2013
    NetCom Learning is an authorized Microsoft learning partner that can help you with .Net certification trainings and passing the exams through guided expert knowledge of certified professionals. Hands-on training and practical exposure deliver in-depth knowledge imbibing essential skills to become successful .Net developer.
Feb 13, 2018 | Microsoft Computers & Internet
Which Microsoft certification should a .Net developer do?
Demand of development and programming skills is skyrocketing. Achieving a developer certification can help you keep an edge in the market by making you stand out among your peers.
To reduce your perplexity, I suggest you following Microsoft Certifications that can help you achieve the promising career opportunities as .Net Developer:
Feb 09, 2018 | Microsoft Computers & Internet
What are the career opportunities of mobile application development and how can it be learned?
You can jump right into mobile application development and learn step by step application development. If your basics aren't clear you won't be able to stand a chance against those frameworks data structure, database, user experience design and other stuff that is required for building an app.
This takes time and it pretty much depends on your Education as well. If you are BSCS student you will have OOP concepts somewhere in your mind you just need to recall them with the programming language of your choice. If you're education is other then Computer Science then you need to start from very basics of OOP (Object Oriented Programming).
First you need to select the OS platform for which you want to develop mobile applications. For IOS you will need to learn C and swift and for android you will need to learn Java and Android Studio there are other technologies as well which offer hybrid application development such as Xamrain React.Native and Apache Cordova as well.
I would recommend you to learn C from the beginning and learn swift which is a tool for developing iOS applications, side by side. Plan everything don't jump into coding from the beginning, Set milestones per month and week. Stick with your plan. Give more time for coding, and my advice wake-up early in the morning to learn to code.
If you can't understand an error don't get hasty in solving that error because its sometimes very hectic to find a single error which might be as small as missing a semi colon ( ; ) try to be polite with errors as that is the only key for resolving errors fast. I hope this helped you and answered your questions.
For development of native mobile application you will need to learn Apache cordova and C# because its a Microsoft development tool powered with Visual Studio IDE. For development in React Native you should have full hands-on experience in JavaScript development, but for many experienced developers JavaScript is a bad choice for beginners.
Jan 13, 2014 | Cars & Trucks
Streets and trips 2011 will not install ?
I had a similar problem installing it on Windows 7 SP1. It may not be the same problem you are having on XP, but it is worth trying.
It seems that Streets and Trips 2011 will not install if the Visual Studio 2010 SP1 Redistributable Package is on the system.
  1. Through the control panel, uninstall the Microsoft Visual Studio 2010 SP1 Redistributable Package.
  2. Install Streets and Trips 2011.
  3. Download and install the Microsoft Visual Studio 2010 SP1 Redistributable Package. Don't skip this step, since SP1 gives you important security updates.
Feb 09, 2012 | Microsoft Computers & Internet
What kind of pc should i buy?
Well, Currently I have an Acer AOA 150, those freaking old netbooks run the visual studio 2010 obviously with windows 7 installed, but basically from now on you can buy any computer with windows 7 [Laptop or Desktop] most of'em will run VS2010.
Jan 23, 2012 | Computers & Internet
MSDN
MSDN Subscriptions help add value throughout the development lifecycle by giving developers access to tools, platforms and community resources that help developers create solutions.
Subscribers have access to a comprehensive set of resources including past, present, and future software and tools. With MSDN Subscribers' enhanced support, you can quickly get un-stuck, enabling you to make the right decisions to stay ahead of the curve. The platform gives you room to grow, as you will always have access to the newest technologies. MSDN Subscribers also get other benefits ranging from 3rd party offers to MSDN Subscribers to discounted products and VIP treatment at events.
You can get a MSDN Subscription as an option when purchasing Microsoft Visual Studio.
May 13, 2011 | Computers & Internet
What is .net? what are the types?
.net is a platform which is used for creating standalone and web application. It is Microsoft technology and competitor of Java. .net is not a language but a framework and supports many languages. It supports around 37 languages. But mostly CSharp and vb.net is used for developing the application. Microsoft Visual Studio is used for developing .net applications.
Regards, polysandy
May 31, 2010 | Microsoft ASP.NET Programming with MS...
How to solve the upgrade patch problem for vs2005
Please send me complete details including your operating system and visual studio service pack version. If you are getting this error for windows vista then you can try later version of VS which works fine with vista and also i want to tell you you can use microsoft visual web developer express or microsoft visual c# developer express edition for the same purpose and also they consume less resources than VS.
Thanks
Jun 24, 2009 | Microsoft Visual Studio 2005 Professional...
Visual Studio 6 Vista compatible?
According to MSDN Visual studio 2005 works on vista ( see here ) . But as a developer, i can suggest you, if it not works, you can easily maintain a dual boot system with another HDD. That would be better for you. A lot of developing tool can not work with vista. I started using vista and threw it away then.
Apr 21, 2009 | Microsoft Mlf Visual Studio Enterprise...
Problem with Compaq Fortran & Vista
I found the solution fortunately:
It's enough to do a right click on the bottom: "Developer Studio" instead of double click, and select: "Run as Administrator" , then select: "Allow" and so on..
Try it, it works!
Aug 06, 2008 | Compaq Visual Fortran Professional Edition...
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
