Question about Kohler Model 10433: Fort® Single-control Pullout Kitchen Sink Faucet Wi...
I've installed a newly purchased Kohler forte 10433-VS faucet but unable to get spray to fully engaged and seems to leave the partial spout running resulting in a in between or partial spray and spout. Is there a way to check or fix this issue so the spray is fully engaged without spout and makes a clean switch to full spout or full spray?
  • shon_hata Jun 01, 2010
    Thank you for the link but the service parts diagram does not show a diverter. However it does show an aerator. Could it be a faulty aerator?
  • 349 Answers
Sounds like the diverter is not working properly. It is located in the spout and it maybe sticking or bad. Go to link below for a installation guide with parts break down. Click on installer's and designer's bar below picture of faucet for a diagram of faucet that may help you out.
http://www.us.kohler.com/onlinecatalog/detail.jsp?from=thumb&frm=&module=Faucet+Collection+Kitchen&item=9559802&prod_num=10433&section=1&category=4&resultPage=0-711729362
Posted on Jun 01, 2010
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
May 12, 2016 | Kohler Model 10433: Fort® Single-control...
Replacing hose on a Kohler model numbe K- 10433
http://411plumb.com/kohler-forte-faucet-troubleshooting-repair-guide/
Mar 11, 2014 | Kohler Model 10433: Fort® Single-control...
I have a Koiler A112.181M or 157-076-ST kitchen faucet. On the back there is a small hole and it is leaking.. What can I do to stop the leak( A small drip) Thank You Jeff
If there is a hole on the spout itself then you should go ahead and replace th.e whole faucet. This will save you both time and money in the long run
Sep 08, 2010 | Kohler Model 10433: Fort® Single-control...
Water leaking from bottom part of the faucet ...not sure if the model is a 10433 Fort Single control pullout
I had a similar problem with my relatively new Forte model. I disassembled the handle, removed the retaining ring and the valve assembly. I thought at first it was the valve assembly but wasn't convinced. I continued to remove the entire faucet hub by gripping and pulling straight up. When I did, the diverter valve popped out of the back to the counter behind the sink. I cleaned all the parts up, made sure all the rings were in place, presse the diverter securely into place back in its hole, and reassembled the rest of the parts. That seemed to do the trick. I'm guessing that the diverter lost its seal and was displaced inside the hub. Hope that helps someone else.
Jul 26, 2010 | Kohler Model 10433: Fort® Single-control...
Kohler K-12177 low water pressure output. Removed
check valves under sink make shure tey are all the way on but spray them into a bucket if you can to see if they are ok.
Oct 25, 2009 | Kohler Model 10433: Fort® Single-control...
Srayer leaking down the hose from pivot joint near spray head
there is an oring in that connection that is most likey bad. turn water off and disconnect coupling to spayer. remove the black oring and match it up at your local hardware store. when installin it lubricate it with vaseline for ease of insatlltion and to help protect it during installation.
Apr 21, 2009 | Kohler Model 10433: Fort® Single-control...
Kohler Model 10433: Fort® Single-control Pullout Kitchen Sink Faucet Wi... Logo
422 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
