Question about RCA F38310 38" TV
CRT the repair guys who came to the house said I need a new "crt", but they have been able to get the part. where can I find it myself so I can my tv working again?
  • niceguyocho
    niceguyocho Apr 12, 2008
    It turns out it isn't the "CRT" itself but the part that connects to the back. I'm not sure what it's called. It looks like some kind of circuit board & another piece between that and the tube.
  • Jaime Hernandez May 11, 2010
    How old is your TV?
    Can you describe what you see on the CRT?
  • 2,326 Answers
It sounds that you are talking about the video amplifier board and the other part is called the "yoke".
Can you provide me with the exact model and chassis number of your TV to find a part supplier that carries those RCA parts.
Posted on Apr 12, 2008
    Sergeant:
    Champion:
  • 375 Answers
The cost will far exceed replacement value if the crt is faulty.
Posted on Apr 08, 2008
My TV display is gone only a shining line appeared. Volume is ok
Having had that problem myself with another brand I would say that either your CRT or Video board has gone out, The board can possibly be repaired but the CRT would need replaced.;
Jun 25, 2014 | Samsung SMC-213 Ultra Slim 21" CRT Color...
I have a Sony model KV-32S26 that will not turn on, been sitting for about 2 years. Had a tv repair guy tell me it was the flyback transformer. If that's the case, can I replace it myself? Thanks
1) You must test the a) fuse b) c.breaker inside c) diode, d) rectifier e) transformer f) filter. g) IC. regulator voltage and test it. If the problem persist you must go to the horizontal problem by lack of RASTER, now you test the transistor horizontal power, flyback. If you have some experience with the electronic you can try. If do not, better go to the repair shop Tv. Since you can have a electric shock by H.Voltage discharge.
God bless you
Oct 11, 2012 | Sony KV-32S26 32" TV
My tv turns green and shuts itself off
Sounds like a CRT rear screen TV so I would say you are having an issue with your Green CRT.
Would need to go into a trusted service shop to have it repaired. I would call around and get an estimate of repair.
Blessings,
A/V Media Tech Guy
Dec 19, 2009 | Sony Televison & Video
T.v repair
Yes,Ur LCD converter board it dead,need replaced.
Nov 22, 2009 | Televison & Video
Philips 60
First of all,this is a major labor intensive repair on Philips TV's changing the blue CRT because the new CRT does not come with the coolant that is sealed between the lens and the tube.If you have never done this type of repair before you should not attempt. Changing the convergence board is one thing (you can solder in two STK392-120 IC's and repair the board instead)
but changing the CRT's can be a nightmare.If you are brave go to PARTSTORE.com and get the parts $600+ (I would order the service manual too...you will need it)
Aug 27, 2008 | Philips 60PP9202 60" Rear Projection...
How to replace red crt on 52" RCA
When a red crt goes out and wont light its usually another reason such as a transistor or even faulty CRT pc board that causes it since the set powers up the other two tubes. Go to this link and leave them an email and list the model number and tell them the symptoms they will help you out with it, they are real good with the RCa sets. If the red tube was shot it would cause the set to go into shutdown or throw red retrace lines across the screen. Heres the link,
http://servicemanuals.vstore.ca/
May 21, 2008 | Televison & Video
Same tv
Get a qualified second opinion............................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Interesting problem...
Install horiz driver kit # 483513057673..applies to all L04.01
chassis....+ replace 47mf/25v cap in horiz driver circuit....T.
Oct 27, 2007 | Philips 32PT5441/37 32" TV
TV repair
The local technicians in Macao say, there is no way to repair it, it is totaly wrong it can bw repaired easily. need to buy a new one... not at all. Is there a problem in a major component or design that make it no viable to repair? in tv no major components except CRT. Any problem with power supply I can do by myself, if you have basic knowledge of electronics you can do it but as you know it is a high voltage device. so bettre to get help from tec. as per fixing is concerned as you are saying power supply it could be due to 1 main filter cap. 2 bridge rectifier diode. 3 switching ckt components like transistor or str. 4 print short. hope this will help. good luck.
Oct 05, 2007 | Televison & Video
Repair shop says Flyback Transformer needs replacement
If you know what you are doing, and you have a good (de)solderstation, you can repaire it yourself, but you don't know if it for sure the transformer. since you did not find the problem yourself, suppose you replace the transformer and your TV does not work !? Even when you repair it yourself, the repair guy shall charge you the cost for his time (I don't know the exact english word for his time checking the TV). And I suppose there is a warranty for his repair. So...
Sep 11, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
RCA F38310 38" TV Logo
76 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
