Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
I have a Pr5 error code on my 2100 raypak heater
Pr5 error code
3 Suggested Answers
  • 864 Answers
SOURCE: raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
Posted on May 30, 2009
adamh294
  • 310 Answers
SOURCE: Raypak pool heater - error code is "FAN"
In models older than 07-07 it typically indicates a loss of the pilot light.
In models newer than 07-07 it is probably the air switch not being activated, or it has just failed. Check air switch tubing for secure connections.
Posted on Oct 27, 2010
Raypak spa heater pr5 service code message
check pressure switch if no voltage both sides of switch bad switch or plugged copper line or loose wires
Oct 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 pool heater won't heat, PRS and HL2 error codes.
Well, I replaced the pressure switch with no joy. I tried all 5 levels of pressure 1-5 and every wiring combination. Finally, I returned the new $70 pressure switch and took the 2 wires and tied them together (jumped them). Here's the only downside...If you run your pump in backwash, recirc, waste, or any mode that would cause water to bypass the heater it MUST BE OFF. Otherwise, let it ride. It's working great and I hope to go into October weather permitting.
May 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
RP2100 - screen error code shows RP5 what does
Their should be no RP5 but their is a PR5 or rather a PRS only on the desplay the S looks like a 5. this means low pressure and will usually be a dirty basket on the pump or a dirty filter. It could also be a problem in the pressure switch on the heater but more often than not it will be a clloged basket or filter.
Nov 23, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 ignites then it turns off or shakes bangs HL1
Check the bypass in the header for damage. HL1 along with the banging/popping is too low of water flow through the heater and the water is getting to hot.
Sep 06, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak 2100 starts then turns off or shake/bangs off w/error HL1
the heater is plump correctly?if yes assembly valve need replacement, if you by pass before dirt may be inside.
Code PR5 comes on
pressure switch is open. check for defective or out of adjustment press. switch.also filter and/or skimmer in need of cleaning
Jul 18, 2009 | Raypak REFRACTORY KIT
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
1,163 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
