Question about Kitchen Ranges
I have a kenmore range with an e1 f5 error code after trying to use self cleaning oven. it now says oven is locked
  • 619 Answers
E-1 F-5 is a faulty door latch switch. Try to turn breaker off to stove for about 30 seconds then turn breaker on while someone is pushing against oven door to relieve pressure. If this does not work try selecting self-clean mode again and then cancel it. If none of these work you will need to replace the lock latch assembly. Hope this helps.
Posted on Jun 02, 2010
  • rpaint01 Nov 13, 2010
    I have a Kenmore 95115102 and all I did was manually cycle the door latch a few times. It's at the top of the chassis when the door is open.
I have a Kenmore 95115102 and all I did was manually cycle the door latch closed/open a few times. It's at the top of the chassis when the door is open. After that, I closed the door and restarted the self cleaning cycle. Worked like a champ.
Posted on Nov 13, 2010
    Genius:
  • 1,417 Answers
Answer
Failed: retry I have a F3 showing on my stove , which according to my booklet is a fault sign to disconneci and (More) (More) F5 showing on your kenmore range , which according to my research is a fault sign to disconnection which will need a repair service
what youn will have to do to fix up your range is to unscrew it and then connect those that have lost their position back properly
thank you and good lock.
Posted on May 31, 2010
SOURCE: E1 F5 error on self cleaning oven
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.
This code means the control has detected a problem with the door latch switch. Switch is defective and needs replaced. Part # is W10107820 and cost is $39.99. You can get it at http://www3.sears.com/.
Before calling a repair shop,go to the circuit breaker box and turn off the power to the oven. then turn it back on and then see if the door is released and the error is cleared.
its probaly bent door latch or door sensor gone bad. try pushing on the door when you start the clean cycle see if that helps.
if not our suggestion would be to replace the part....
good luck...
if you got insight into your problem from us , A very helpful rating is appreciated for answering your question
Posted on Aug 10, 2009
heatman101
  • 43501 Answers
SOURCE: Whirlpool Self Cleaning oven error code
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Jul 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: I tried to set my self-cleaning on my Electric
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: We used the self cleaning option on our Kenmore
Posted on Sep 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 95024 Electric Range The self clean cycle Door stuck shu
I did the self clean on my oven, and now the oven door will not unlock (E1-F5-) pops up onto the oven screen.
Hi
Error E1 F5 means that the control has detected a problem with door latch switch. Switch off the power and unplug it from the mains. Check after 5-6 minutes whether the error has disappeared. If the error is still there then once again start the self clean cycle. Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Try moving the latch manually to unlock it. hope this helps...
Daniel
Aug 28, 2010 | Kenmore 92002 / 92004 Kitchen Range
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Jun 27, 2010 | Kenmore 95022 / 95024 / 95029 Electric...
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Trying to self clean my kenmore electric oven get error msg e1 f5
Oct 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I tried to set my self-cleaning on my Electric Kenmore range model # 66592012100 and I get the error message E1 F5 I can't set my oven to self-clean just my luck
May 13, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
KEMORE OVEN SELF CLEANING
Aug 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven locked after celf cleaning
Aug 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
Kitchen Ranges Logo
508 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
