Question about Brother HL-2170W Laser Printer
Printer was working fine, until it's outflow was accidentally obstructed. Obstruction removed, but now error light comes on immediately, and printer won't print. There is nothing blocking the paper path, no paper jam. Ideas?
    Guru:
  • 528 Answers
Try this troubleshooting prodedure. Turn on/off, unplug, plug inprinter was working fine, until - 2_bing.gif, should reset configs.
Take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck preventing from accepting paper.
Go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
Go to web site of printer model and check site for trouble shooting if this does not work above. Hope this helps and good luck
Posted on May 31, 2010
Fuji finepix
When a camera notice the lens does not move, it is afraid to damage gears or the motor, of it powers down everything involved the lens. It then gives a message as you read.
Because the camera can't know what is casing this, it only can warn.
It "hopes" if it did run the lens to an obstruction, powering it down will relieve the tension. That is way it says power down.
Remove the battery, check the lens barrel if any obstruction is limiting the free movement of the lens. and then replace the battery. switch it on again.
If you accidentally touched the lens, while it was coming out, it could have given the same error. When after switching on the camera, and you are sure you don't obstruct the free movement of the lens barrel, but it comes back with the same error, you should contact a certified repair centre for your camera.
Jul 20, 2014 | Fujifilm Finepix S2980
Pixma mx922 start up error (6901)
You may find a foreign object or paper fragment inside the paper path. The machine will detect this immediately on start up and won't proceed until the obstruction is removed. Open everything and look carefully, sometimes these are difficult to find.
May 03, 2014 | Canon Pixma MX922
Carriage stall.. clear carriage obstruction and press resume...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jul 27, 2010 | HP cp1700 Color Inkjet Printer
Paper jam error displayed on the lcd of printer....if you clear the jam and then you try to test the printer still same problem...the paper are wrinkled in the fuser assembly...
Remove the paper,and check for obstruction in the pathway.
Usually stuff children would incert.
Or stuff thatfall in accidentally
Like small coins, paper clips, creans etc.
Jan 20, 2010 | Brother HL 6050D Printer
Cartridge cradle can't move, says paper is empty when it's not
OK....try removing the carts, close the printer, turn off, then disconnect...alot of the problems with the newer HP printers has to do with their ROM memory....if that doesn't work, then there is defintely something in the paper path, no matter how small. Try to eliminate the copy function....does the error happen as soon as the printer is finished powering up??
Jul 23, 2009 | HP Deskjet F2210 InkJet Printer
Canon MP210 roller not ressponsive
I saw a similar situation with an adapter for a Sony produo memory card wedged in the rollers.When removed, the printer worked fine.Have a good torch to hand and a long narrow strip of card to poke around with without doing any harm. If you can manage it, turn the printer upside down and shake gently, this may help to dislodge any obstruction.
Dec 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Printer will not print. error messge number 5100A paper does not feed
My Epson CX4200 was flashing error for apparently no reason. I was instructed to remove any obstruction, unplug, and wait several minutes before turning it back on. I could find no obstruction and the unplugging wasn't working. Finally I turned the machine upside down and shook it violently. This must have dislodged some particle I could not see because the printer now works fine.
Aug 10, 2008 | Office Equipment & Supplies
HP 3820 Deskjet Printer
1) take a flash light and inspect the paper path just to make sure there really is nothing there.
2) print a test page from the printer by pressing the big button ( I think) one of the buttons, can't remember I work on so many models
3) take out cart. turn off then on, install cart. and do step 2
what happens
Jan 04, 2008 | HP DeskJet 3820 InkJet Printer
Error light & 7 beeps
geez, going back in time,but it is a print position fault, head is not traveling correctly , make sure rail is lubed and carriage can move back and forth without obstruction,
Oct 26, 2007 | Canon BJC 80 InkJet Printer
Brother HL-2170W Laser Printer Logo
222 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
