Question about Dewalt 18 Volt Compact Drill Kit
Jammed chuck the chuck is jammed on my 18v Dewalt drill . There is a bit stuck in it and it wont even budge . I think the chuck is pooched but the drill is hardly used . Does anyone have any ideas how to fix this ?
  • 10,865 Answers
Use a pipe wrench to turn the chuck open. J.
Posted on May 31, 2010
I have a DeWalt DW505 hammer drill. I was drilling into concrete and my bit came out. After several attempts to drill again, I noticed the drill chuck was not holding the bit. I opened the chuck all the...
Hi Ken, sadly it sounds like the chuck is past its best. The cogs inside the chuck have most probably worn. If you can get the chuck off try clamping it in a vice and use some pump pliers to undo it. Failing that you will need a new chuck which you may be able to get at a good diy store.
Sep 14, 2013 | Dewalt DW505 Electric hammer drills
Jaws won't tighten or loosen to hold a bit
Hmmm some times the counterclockwise screw that attaches the chuck to the drill come forward and that is how then it stucks the 3 parts that fix a drill to a chuck. Check if this screw come forward. If yes then destroy it and replace it... We destroy it by using a drill smaller than it (usually it is 5mm so we use 4mm bit and of course a CARBIDE one because even cobalt ones can not drill a hardened bolt)
Mar 26, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
I can't get the teeth to close around the bit? It is stuck open any solutions?
Some chucks have a screw in side the chuck maybe a star-head it could be lose.
Feb 05, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My drill bit has stuck in the chuck of my dewalt sds chuck ,have tried wd40 but still stuck
I had the same problem. I put the drill onto Hammer/Chisel action and it helped release the bit.
May 16, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Chuck wont come off dewalt cordless drill 18v xrp my chuck bolt insid of the chuck wont come out and i need to know if it is reverse thred or not
i cant say 100% sure for that drill but im betting its not.
it probably has red loctite on it which is very tough to break free. put some heat to it. then it will come easily
Mar 16, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Seized chuck.
I would continue to use the rust remover/penetrating oil products, put a pair of vice grips on the chuck grip and use a hammer to tap the grips. Hopefully this will free it up. It's not very elegant and you probably have already tried similar methods but it's the best idea that I have. Also you could soak the chuck portion in penetrating oil (chuck submerged only) overnight. Good luck!
Mar 01, 2010 | Dewalt 18v 1/2" Compact Drill/driver Kit...
I have a DCD940KX 18v Dewalt drill driver with the one click drill chuck. It does not keep drill bits or screwdriver bits from spinning. They spin with the slightest bit of pressure on them. My questions...
this is not a common problem with dewalt. I have been using them in my construction business for years and only heard of this once or twice. I would go to their web site and get the number for their customer service. They stand behind their products and im sure they will help in every way they can to repair the drill
Nov 26, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt 18 volt cordless drill the chuck is stuck in the fully open position and wont close
Use a pipe wrench on it to give yourself a little more leverage. It is simply jammed all the way open and it will release when you apply enough force.
Apr 30, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Feb 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt 18 Volt Compact Drill Kit Logo
1,159 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
