A E544 code is a sorter problem if it is a Canon copier. If it is a Canon look to see if the stapler has a jamed staple it and remove it. The front door of the sorter should have a picture to show how to remove it or remove a jam. If the bins are stuck or broken thry to turn the copier Off and unplug the sorter and turn the copier back on if it clears try to turn it Off and reinstall the sorter plug and turn it back On. If the code comes back try to see if you can detach the soter from the main body of the copier and unplug it from the back of the copier and make a exit tray for the copier. Good Luck
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Cancel twice
