Question about Dell (E210882) Motherboard
My Dell desktop motherboard doesn't work. Is it possible to transfer information to my new desktop-also a Dell ? Is there a creature called a motherboard dock?
    President:
  • 995 Answers
Hi!
Yes it is possible to transfer all your data and information to your new desktop computer. Just get the hard disk drive out from your old computer and then plug it to your computer.
And with the motherboard dock you mention, a system casing is probably the best to dock your motherboard.
Thank you for reaching us.
Have a nice day!
Posted on Jun 01, 2010
Testimonial: "Sounds good, but how do I plug it in to my new computer or case it, computer repair novice."
  • Aldrine Manalo
    Aldrine Manalo Jun 02, 2010
    To remove your hard drive out from your old computer you need the following:
    1. Philips Screw Driver
    2. Anti-static wrist ban (Optional)
    Steps:
    1. Make sure your computer power is unplugged before you start.
    2. Open the computer system case. You will now see the inside of your system case. The motherboard, hard drives, powersupplies, etc.
    3. Now use the philips screw driver to remove the hard disk out of the drive bay.
    Now in your new computer, just follow the steps 1 and 2 and then with the help of the screw driver, secure the hard drive into the drive bay.
    Use the old drive as a secondary master then plug the IDE ribbon connector to IDE2 header connector or if you are using a sata hard drive, then plug it into any available sata port in the motherboard.
    Don't forget to plug the drive power connector.
    That's all..:-)
    Have a nice day!
Transfering data from damaged motherboard
The motherboard does not store any information. The hard drive stores all the information. If the motherboard is damaged, you have to either buy a new motherboard or remove the hard drive and install it into another computer.
Feb 09, 2014 | Dell Inspiron Computers & Internet
Dell 054km3
Memory
Type DDR3 SDRAM (non-ECC memory only)
Speed 1066 MHz, 1333 MHz
Connectors four
Capacity 1 GB, 2 GB, or 4 GB
Minimum memory 1 GB
Maximum memory 16 GB
Sep 21, 2013 | Computers & Internet
The mother board is burn up and the fan do not come on in my dell 530s computer, can i transfer my file to my new dell Inspiron 570mt computer
Remove the harddisk from the old PC and connect it to the new pc's motherboard as secondary harddisk then start transferring files to the primary harddisk of the new PC.
Sep 03, 2010 | Dell Inspiron 530 -Intel® Pentium®...
I have a Dell GX270 and i replaced the P4 2.4 Processor with a P4 2.8 and now all i get when i turn it on is a sollid amber light on the power switch, Nothing else. Does not boot. Can you tell me what is...
Its possible the motherboard does not support the new processor. its possible there might be a firmware update for the motherboard to add support, otherwise you might be out of luck.
Swap processors back, confirm that it works again, and if possible confirm that the new P4 is in fact working.
Apr 07, 2010 | Dell OptiPlex GX270 PC Desktop
Getting my dell motherboards to start up.......
you might have fried the mobo when transferring it, and try it with a monitor see if anything comes up on the screen at startup
Oct 08, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 5100 Network Card Issue
my friend if it is not on board network card, un plug the card and replace with the new one and then u make sure that u follow the instructions given when installing and also u have to configure again the ip adress or net work set up as before
May 22, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell deminson 4600 fails to power up, power supply tested ok.
No beebs, no bueno. Unplug the power cord. Unplug the wide multi colored adapter from the motherboard and reseat it. make sure the other conntections are firm while you're down there and have the case open.
If you don't know what I'm talking about or don't want to crack open your PC then buy a new Dell and hae someone slave up your drive and transfer the information.
Jul 16, 2008 | Computers & Internet
DELL INSPIRON E1505 NOTEBOOK (Motherboard/ Hard Drive Problems)
You have 2 solutions here, basically.
1 - Buy an external hard drive enclosure for laptop hard drive and connect that via USB to your desktop. After that, Windows should pick it up as an external drive, like a USB stick.
2 - If you can get the computer to turn on, you can connect the laptop and desktop together via network card (ethernet cable) with a CrossOver cable. You'd set the desktop IP settings statically to 192.168.1.1, 255.255.255.0, 192.168.1.1 and the laptop to 192.168.1.2, 255.255.255.0, 192.168.1.1. Then you'd just browse from one to the other by \\<computername>\c$, log in if it asks, and copy what you need.
May 16, 2008 | HP Compaq Motherboard
Motherboard blew up
I would recommend buying a replacement computer, and install the Dell IDE drive in an external 3.5" IDE hard drive enclosure. This way you can pull your information off the the Dell hard drive, and then blow it away.
Keep in mind that new computers use a SATA drive, your old Dell '8200 has an IDE drive. Also keep in mind that your Dimension 8200 drivers won't work on the new computer.
You might be able to install your Dell drive as a slave if you have an open IDE channel available.
Good news is, your old Dell uses RAMBUS memory, which is worth a lot. It's a good parts computer, and most people who look for computer parts know of the bad capacitor issue on Intel made Dell motherboards from that era.
May 15, 2008 | Dell Dimension 8200 PC Desktop
Dell (E210882) Motherboard Logo
254 people viewed this question
Alun Cox
