Question about GPS
F-10 navman showing a screen with a laptop with a pulsing line to a usb icon and a none pulsing line to the navman icon
  • psdcyew Mar 30, 2009
I need to find a software download to install my navman f10
Posted on Sep 07, 2008
How can i change my navman from German to English. Thank
  • Press the "Main Menu" button on the Navman to bring up a list of options. Tap "Preferences," choose "Localize" and "Language." Each option is selected by touching the screen. The different language options show up on the screen in list format. Touch the language you want to use and press the check mark icon. The Navman will now operate in the chosen language.
  • Jul 01, 2011 | Computers & Internet
    Screen is showing computer, usb connection, navman which are joined together by a serious of dots with the computer screen to usb connection showing green lights
    The F20 Desktop Software and Service pack on the CD's from navman do not work, as you have seen. The solution is to go to the navman website and download this Service Pack
    Be sure your f20 is connected to the USB cable and turned on displaying the USB Connection screen. Leave it on during the entire process.
    Once downloaded, run this self extracting file and let it install automatically. After it is installed and ran.....you will see the same error again of failure to connect.
    At this point you must reinstall the driver manually. Right click on your "My Computer icon, Select Devices, then properties on the navman. You should see a yellow "?" next to a statement "Unknown Device" in the USB devices. Click on the "Reinstall Driver" and select a specific location or the Have Disk button. The USB driver is now located in C:\program files\Navman\f20servicepack\USB directory.
    You should get a button that now says Okay at the bottom, click onto it and allow the MS program to update the drivers. You should see the device screen change and say "This device is operating properly". You can then close the windows and run the F20 desktop program. It should connect then.
    Jul 06, 2008 | Navman GPS
    Navman My50T - screen has frozen, can't get any other screen apart from initial start-up screen (except for screen showing connected to computer when connected by usb).
    Had a similar problem with a MY60T.
    Spoke to Navman support.
    1. Connect your unit to the computer.
    2. Use windows explorer to go to the Navman folder
    3. Go to the database folder.
    4. Delete "Database.db"
    5. Switch off & re-start you unit. The databse file is re-created on startup
    Dec 24, 2010 | GPS
    My navman s45 seems to be frozen or just stuck on the same route also after i have reset it it still goes back to the same route which is stuck on and cant be cleared and the touch screen buttons dont work...
    1. Connect Navman GPS to PC via mini-USB cable.
    2. Go to 'Start'
    3. Go to 'My Computer'
    4. Open the Navman Unit
    5. Open the 'Navman' folder
    6. Open the 'Database' folder
    7. Delete the following file only - 'dababase.db'
    8. Close the folders
    9. Disconnect the mini-USB cable then restart the Navman GPS by sliding the switch to 'Restart' then back to 'On' after 10 seconds.
    The database.db file will be generated automatically once the folder is closed.
    Nov 04, 2010 | GPS
    Navman MY75T was working fine for several weeks, but today it won't start up. Tried to reset several times, but no luck. It gets to the Safety Agreement screen, and when I press the "Accept"...
    1. Connect Navman GPS to PC viamini-usb cable. 2. Go to 'Start' 3. Go to 'My Computer' 4. Open the 'Navman' folder 5. Open the 'Database' folder 6. Delete the following file only- 'dababase.db' 7. Close the folders 8. Disconnect the mini-USB cablethen restart the Navman GPS by sliding the switch to 'Restart' then back to'On' after 10 seconds. The unit shouldstart & the database.db file will be re-generated automatically.
    Nov 02, 2010 | GPS
    Screen is frozen, can be turned on and off but wont go passed initial stage
    May 17, 2010 | CaseCrown Navman S50 Portable GPS...
    Navman F10 wont function shows sat nav connecting to computer on screen
    Try holding down on/off button till screen clears,switch back on and it should be working normally,this worked on mine,it had picture of laptop ,navman usb cable and a red cross,hope this helps.Cheers.
    Jun 10, 2008 | Navman F20 GPS Receiver
    Navman icn 520 stuck on USB screen
    I had this problem when I completely deleted the Backup folder from \My Flash Disk.
    Restoring the backup folder allowed the 520 to operate properly again.
    It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
    Hope this helps.
    May 11, 2008 | Navman iCN 520 GPS Receiver
    Navman S50 wont load maps
    Hi, my probelm is very similar I turn it on and it shows a laptop, usb connection and the navman with a usb cable connecting them together,it also has circle running back an fourth
    Feb 08, 2008 | GPS
    Navman f10
    i was in car,using navmanf10, went blank and a comput screen connect to unit appeared, cannot do anything with it
    pamelathanson@aol.com
    Dec 28, 2007 | Navman Tracker 5500i GPS Receiver
    GPS Logo
    267 people viewed this question
    Top GPS Experts
    Will Halftowaite
    Are you a GPS Expert? Answer questions, earn points and help others
