Question about Brother HL-2040 Laser Printer
My printouts have a very dark haze over them.......the printed letter are fine but it looks like the print cartrige is dumping ink on my paper as it prints. It look like a bad fax copy. What is the problem?
    Scholar:
  • 162 Answers
Either you purchased a a bad quality remanufactured toner cartridge or your fuser film is damaged.
If there is some kind of debris in black color that is on printouts, your fuser film might be damaged. Have a printer technician replace it.
If there is no debris, only bad quality printouts, it's the toner cartridge that needs replacement.
Posted on May 31, 2010
Letter outline printing detail
your copier not set paper size.Paper seize is miss mach so several times print same print
Jul 13, 2012 | Canon imageRUNNER C6800 Copier
My printer prints pictures fine but when i print words it dont print black ink just colors why
Black printer ink in Canon Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Nov 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
HP C4280 printer always prints with a shadowed letters, especially with the black ink. i think it started when i was installing a new cartridge and i didn't insert it at the correct angle, so i may have...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 08, 2010 | HP Photosmart C4280 Aio Printer
Printing blank paper
At a guess you've bought a compatible generic cartrige. I had a similar problem different printer.
I had to by a genuine cartrige, worked fine. Contacted the generic cartrige provider, explained the problem. Returned cartriges and got refund no problem.
It looks like the generic cartrige makers are seeing some solutions to chipped cartridges but not all.
Mar 13, 2010 | Dell 922 All-In-One InkJet Printer
When i try print my pictures they are coming out blurred. how can i stop this
1) Do they look good on your PC. If so its a printer issue if not, for some reason or other, you're not taking good photos
2) If they're good on the PC and print poorly then its a printer issue. Which can be many and varied.
Usually, the wrong kind of paper. If you use ordinary vice photo quality paper the ink can run.
Size, are you trying to print a small picture, say designed for 6x4 inches out on a piece of A4 at A4 size.
Printer settings, are the set to the correct type of paper and for photo printouts.
Ink, generaly, generic cartriges don't quite match the accuracy of manufacturer cartriges.
Mar 07, 2010 | Samsung Digimax A503 Digital Camera
When I print the picture has a purple haze in it ?
If you are using re-manufactured ink tanks, that would explain it, a mi-matched ink tank. To clarify the ink colour is not quite right.
If genuine ink tanks (Recommended) then maybe try different paper. If using photo paper you should be using compatible / genuine paper as the different chemicals react can give this problem.
If using fax / standard paper then could be print head fault....normally get an error code.
Jan 26, 2010 | Dell P703w Printer
Printing won't work.
Good day sir/maam, hi, when you test print it usually prints letters and no lines are printed. try first if the printer is setup to economy/draft or pictures, if lines are faded, the ink cartridges maybe dirty. manual cleaning is needed, the ink path starts from the ink cartridge to the cradle or carrier then to paper. so any dried ink that blocks the path can affect the printout. you can use warm water to loosen dried ink. remove the cartridges and cradle from the printer as you clean them.
Oct 27, 2009 | Office Equipment & Supplies
Blank printout
If you are able to drag out your users manual, most lazer printers have a self cleaning process for the head, which takes around 3-5 minutes to complete, after that try to run a test page to ensure the colors are working fine.
Failing that, unless the printer is brand new, and or unless it has been sitting ( unused - regardless of age ) the print heads can dry out leaving a blockage ... hence, no ink, hence blank page.
The only other suggestion after running a Print head clean, would be to replace or refill the ink cartridges.
Jan 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
Brother HL-2040 Laser Printer Logo
315 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
