Question about Pride Mobility Products Jazzy 1170 XL Plus
When removing the seat I damaged the cable that goes from the motor to the joystick. it is from an older model 1170 and is round with 2 larger prongs with 4 smaller around it. can I get a replacement
  • 10,865 Answers
Yes. go to this site and order the part http://www.monsterscooterparts.com/japoch.html
J.
Posted on May 31, 2010
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Apr 04, 2014 | Woods Industries 12/3X100FT Yellow Jacket...
Nutron r51
The age of the Nutron is not the issue, unfortunately. I have seen problems with this model right out of the box. The joystick control is the first area to check. If you have to compensate the joystick so far to the right to correct, you may have a damaged joystick gimbal. You may also have a bad joystick control board or damaged connecting cable to the controller on the bottom frame. Check for damaged, pinched loose or disconnected wiring below at the controller module. With a folding frame it is easy for the wiring to be become damaged or dislodged. Check for cut damaged pinched wiring at the joystick. With a handheld programmer (dealer) you can check for error codes in the fault log. With a poor performance issue there may not be a fault recorded in the log of the computer module. I have also seen these motors fail prematurely. In this case your left motor is dragging or weak causing the chair to go left. With a programmer (dealer tool) you can compensate for this while waiting for new parts(temp fix). Sometimes the motor brushes burn or hang up. Try blocking up the chair off the ground and run it no load to check for motor performance and unusual sounds. Check for joystick dead spots or uneven action. A quick check of the joystick would be to plug in a known good one at the dealer to test. With the chair blocked up try tapping the motor housing to see if the performance changes. Inspect the brushes if you have access to the brush caps.Check the obvious first, plugs, pinched, broken wires and partial plug disconnects and corrosion. If you have a voltmeter you can do some checks on the motors and brakes. Going from memory, the motor leads large black and large red should read zero ohms with the 2 small white wires for the brake reading between 60 and 70 ohms. Check the Invacare manufacturer website for exact specs and technical info for this model.
Hope this helps.
Mar 22, 2014 | Invacare Supply Group Nutron R51 LXP...
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
How do I get to the batteries ?
The batteries are located under the shroud.In order to accesss theses batteries follow my steps ... 1) Disconnect your joystick cable from the chair.The cable is the cord coming out of the joystick .It will be plugged into the back of the power chair We are doing this to because it helps to have it out of the way 2) once cord is disconnected we will take off the seat. Notice your seat is locked on by four wpigns ,located under the seat 3) Pull four pins, the seat will come off now 4) Remove the colored shroud, Once shroud is removed , you have made it to your batteries Remember Shen putting back together to put your pins back Good luck
Feb 11, 2011 | Golden Technologies Alante 2 Heavy Duty...
Hi my washing machine is working properly. The dial that you select the washing programme keeps clicking round so it doesn't spin or wash. You can hear the motor working and go through a cycle but the drum...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Nov 16, 2010 | Washing Machines
Chair goes in opposite direction to joy stick control left and right only
batrans your motor connections are reversed. remove the seat and shroud over the batteries find the motor connectors that come from the joystick cable and switch them. This should fix your problem Hope you geterdone
Sep 13, 2010 | Jet 3 Ultra Power Chair
I change the coupler of a kenmore washer, but when i starter to work again, there is a noice, kind a ruber noice.
I'd pull the cabinet and check the coupler again.
If you havn't completely seated the plastic pieces, the rubber can be damaged and you'd hear/smell rubber burning.
Jun 12, 2010 | Kenmore 24032\24036 Top Load Washer
Washer motor running but not agitating.it happened before and i change some kind of round rubber with plastic that have 3 tab in it.i just cant remember how did i do that to replace it or where did i take...
See the section on the Motor.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts. Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
Oct 20, 2009 | Kenmore Washing Machines
New climate control unit but when on blower not working for heat or ac
I'm assuming the problem is the blower motor isn't coming on or working. 1st, check the fuse. 2nd, remove the glove box or pull the 2 tabs that act like stops when it's open ( the glove box will open out further) and you'll see the power plug connector for the blower unit. Turn on the blower through the climate control (heat, A/C, or whatever) and wiggle the connector to see if the blower turns on. If starts working, then an easy solution is pull the connector off and gently press the prongs together or inward. Then carefully reconnect with damaging the prongs. This worked for 96 Mark VIII due to the fact the prongs were not "seating" correctly in the female connector. It's been about 2 years since I did this and the connection is still good. If wiggling the plug doesn't work, pull the plug, turn on the climate control (heat, A/C), and check for voltage to the plug. That's about all I can help with.
Apr 20, 2009 | 1998 Lincoln Mark VIII
Jazzy 1420 not 1170
sounds like the wiring from the motor to the controler is not making good connection, try unpluging motor wiring from controller box. Use a plastic safe elec. contact cleaner and lube spray on connections. water in the joystick can also cause this.
Jan 05, 2009 | Pride Mobility Products Jazzy 1170 XL Plus
Pride Mobility Products Jazzy 1170 XL Plus Logo
44 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
