Question about Polaroid TLA-04011C 40 in. LCD TV
Polaroid tv has three black spots on the screen how can i fix it?
SOURCE: Polaroid LCD TV 37" Black screen
I had the same problem. But found the fix on this website!!
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Sep 05, 2008
SOURCE: polaroid flm373b
Try several different inputs.
Posted on Sep 09, 2008
  • 4 Answers
SOURCE: 42' polaroid tv wont show screen still
well if the light stays blue , that means its still on ...what you may need to do is go to your menue and select the setup selection and then go to tuning band.....i belive it will be on page 32 of you manual, under customising the setup settings....in order for the tv to start working it needs to be able to scan for channels.....if you are useing a cable company like comcast or direct tv...depending on how you pluged it into the tv ,(like using the input 1 or 2 , s-vidio, cable , ectra,)...you need to push the input button thats on the lower right side of your remote and select the propper input area as to how you hooked up your cable box
Posted on Dec 14, 2008
RNS-Systems
  • 120 Answers
SOURCE: screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Posted on Oct 16, 2009
SOURCE: Polaroid TLX-04240B going to a black screen.
open the black plastic panel and the aluminum panel which has 3 screws each in the back of the tv.
look at bottom left corner of top board. to the right of the red led light,
there's these four white small switches. turn the bottom two switches to "on" and tv should be working.
It's very simple to fix the problem to everyone.
My tv capacitor was not the problem.
I hope this will help everybody.
Posted on Apr 30, 2010
Two large circular black spots on sceen
LCD Display Panel/screen is damaged. Replacement of the LCD Panel is only solution of the problem. By the way, cost of LCD display may be higher than the cost of new TV. Check you local market for the price.
Apr 19, 2014 | Polaroid TLA-04011C 40 in. LCD TV
Polaroid LCD tv - model TLX-04244b . Flashes the blue polaroid screen then goes black ,I hear a buzz coming from the inverter board. I have replaced both inverter boards and the same problems exisis .
I just changed out the invertor boards and mine was fixed. I had the same problem. Im not a TV repair man but replace the board thats buzzing and it will work again.
Jun 23, 2012 | Polaroid 4226TLMB 42 in. LCD TV
I have a 37 inches polaroid tv and, it was working fine at night, in the morning when I turn it on, a a black spot show on the right side of the screen
Depending which model, this tv may have an inverter master and slave module set. I find best to replace as a pair. These modules feed the flourescent lamps that backlight you lcd screen. more than likely the one failing is on the same side as the spot you are seeing. I always first look at the power supply panel, to be certain that capacitors on this board have not failed or leaked out.
Parts look here http://www.shopjimmy.com/tvs
Jul 09, 2011 | Polaroid TLA-04011C 40 in. LCD TV
There is a black spot in the screen. How do I get it out?
Hello:
LCD TVs have millions of "pixels" that change color to make up a complete picture. Sometimes in the manufacturing process, pixels can become damaged (called "dead pixels"). There is no way for the consumer to fix these. Most manufacturers have a certain number of pixels that are "allowed" to be broken before they will fix it.
You should contact either the vendor you purchased the TV from, or Polaroid support.
You can contact Polaroid Support at 1-800-POLAROID (1-800-765-2764).
Mar 06, 2011 | Polaroid TLA-04011C 40 in. LCD TV
Polaroid TLA-04011c 40 inch. LCD TV? How can u fix TV plasma screen? my friends kids hit the tv screen for with wii remote. i think they broke the tv screen from the one side. and how much it cost to fix...
Sorry this tv can't be fix acept replaced the whloe picture screen panel itself,the tvs screen panels are in of the limited production by the tvs industries,only can buy picture screen panel from the tvs themselves and it 90% important to the tv,will cost u the same as a new tv to get picture screen replaced.Sorry doesn't worth as a whole tv anymorre the tv now only worth as salvages tv for it electronic boards for spare parts for other tv,that it.
Dec 19, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Polaroid TLX-04240B going to a black screen after running for 2mins. Any ideas on how to fix this?
Jan 04, 2010 | Televison & Video
I have a 42" Polaroid flat screen. On the top of the screen three dots about two inches wide each appeared. Wondering what the problem is and if there is a warranty available yet?
Blossom, I would take it in immediatly to a qualified TV Service Shop or where you bought it from to see if you can either return it or actually get it in for repair. With the size of the three dark spots it's more than a dead pixel issue. Could be a matrix processing issue but one Polaroid should repair/fix under warranty.
Happy Thanks Giving,
Blessings always,
A/V Media Tech Guy
Nov 23, 2009 | Polaroid FLM-2632 Television
Polaroid fdm-0700 with black screen display. DVD
go here and order the replacement inverter board. this will fix the backlight issue or no picture issue
http://lcdparts.net/LCDTVInverterdetail.aspx?InverterOriginal=UI8007S-1MSS
Aug 09, 2009 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Polaroid 4241-TLXB wont stay on
I think I may have just solved this issue. Remove the back covers and turn the tv on until it the screen goes black. There will be a little red led that will light up when the screen goes black. right above that light there is 4 little swiches, the bottom one is labled BURN. Switch that one to the opposite direction. I don't know how but mine has been working for a couple days now with no issues. GOOD LUCK!
Jul 05, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
Aug 28, 2008 | Polaroid FLM-3732 Television
Polaroid TLA-04011C 40 in. LCD TV Logo
340 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
