BOSCH CLASSIXX 1200 EXPRESS WASHING MACHINE 5 YRS OLD - PROGRAMME STICKS WHEN SPIN IS REACHED. NOT SPINNING, WATER NOT DRAINING. ADVICE APPRECIATED.
The 03 error code is the drain. Disconnect the drain hoses
and check for blockages. If no blockage "time" the drain interval. If
it's more than 6 minutes it's the pump. Also make sure you're using the
correct
type of soap so the ball check valve on the bottom of the outer drum
isn't
getting fouled with excessive suds. Also disconnect the drain hose from
your
house plumbing and let it free flow on it's own. This will tell you if
the
block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
The strange thing is it worked on spin and drain but not on quick wash is there a ball supposed to be in the drain pipe from machine like a ping pong ball
Can anyone help please
Yes, there is a ball.
How do you set the spin only programme
Via controls on machine spin and drain
Of course there is a ball; to locate it disconnect the clip of the pipe beneath the drum, examine & refit as you found it. It is a trap to catch coins, etc; some much shd be there.
Muck, I mean. The muck is within the hose, beneath drum.
