Question about Fisher Paykel EcoSmart GWL15
Fisher&Paykel model GWL11 won't go into spin cycle
Lid won't lock, LED for spin is lit, water continues to come in, some is draining out at the same time
  • Fisher Master
  • 8,220 Answers
I have an old manual that may shed some light: GWL03 service guide
Posted on May 31, 2010
Fisher and paykel model no GW611 washes but won't spin nor lid locks
Sounds like the lid lock has gone bad. Check the wire connections to it and if you should need to order the lock, here is their website.
Nov 05, 2012 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
Washing machine won't go thru spin cycle. Lid lock light flashed some at first, now won't come on at all.
Hi there the lid lock switch is faulty and needs to be replaced - cannot be bypassed unfortunately.
Jul 14, 2011 | Fisher and Paykel GWL11 Top Load Washer
Have Fisher & Paykel washer GW11. 5 yrs old. Lid won't lock, Took off to repair, then put back on, no problem, but now won't lock, so won't spin. Help!
your door needs to be re-aligned so the wax motor assy can lock the door so the unit senses its locked and can continue the wash cycles
Jul 16, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a GWL11 Fisher Paykel washer. It was running fine then it was beeping and had stopped-- the spin light was the only one left on, although water is in it. Basin looks lower than I recall. It won't...
Hi just read you posting.Now when the machine was beeping was the spin light the only light that was on while it was beeping?If this is the case then my manual tells me your Motor Controller is faulty and needs replacing.Please confirm which light was on when the machine was beeping because the motor controller module is not cheap.Looking forward to your reply.
Jun 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
Stops before rinse cycle... won't drain or spin.
The REGULAR CYCLE button turns the drain pump on or off. The REGULAR LED will turn
on when the pump is on. This feature can be used to drain the tub. You could get a bucket and lay the hose on the fllor. Gravity will drain it down.
Sep 07, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing machine will not spin or drain
look at my post "eco smart won't drain, smells hot". It could be something stuck in very lowest part fo drainage area. you have to remove the motor on bottom of washer to see into this area and remove blockage.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 will not drain...
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 09, 2008 | Fisher and Paykel GWL11 Top Load Washer
My fisher paykel eco smart is GWL11 not GWL15
Press "end of cycle" for 5 seconds or more to clear the screen. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
206 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
