Question about Tech Solution TS-4500 Shredder
Shreds in reverse only
My paper shedder will shred in reverse (sometimes) but not in forward . It was working great then all of a sudden without any kind of problem it stopped shredding.
  • 8,404 Answers
I think there is a shredded buildup on the bottom. Unlpug the device ... turn it over and clear out the residue you will find there.
Sometimes I find the addition of shredder oil during the shredding process helps to eliminate this problem. Get the oil where shredders are sold.
Posted on May 31, 2010
My Executive Machines EPS 1200X shredder works in reverse, but does not shred.
there should be a forward/ reverse switch that is used to unjam paper being shredded. check that
if it is automatic then check for paper stuck in the shredder causing the reverse action.
May 12, 2015 | Shredder Office Equipment & Supplies
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
HOW DO I UNJAM SB 99C SHEDDER
Try spraying some WD40 into the cutting blades then turn it on to forward it may unjam itself.
Aug 25, 2014 | Fellowes SB-99Ci Shredder
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
The paper is stuck in the shedder and now it will not turn on/off
Try reverse, forward, reverse a few times. If thet doesn't work, unplug it, turn the shredding unit off and pick out whatever paper you can see, both top and bottom. Watch your fingers, the cutters are sharp.
Aug 10, 2009 | Fellowes DM8C Cross-Cut Shredder
Need a sensor switch for fellows powershred 220. Won't sense paper.
The top sensors may be bad or even the main board that they are connected to is bad. Try cleaning them with a lightly moistened swab or compressed air. Fellowes will sell you the parts.
Apr 29, 2009 | Fellowes Powershred 220 Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Shredder won't shred any more.
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Mar 27, 2008 | Office Equipment & Supplies
Shedder one works
This is an issue with the paper feed sensor which may be a electronic eye or a mechanical switch if it is mecanical you may just have to jiggle the switch a few times, occasionally paper may get stuck behind it not letting it activate. If it is electronic you have bad sensors or bad pc board and you'll have to contact the manufacturer for further info.
Mar 07, 2008 | Aurora Global AS501X-MS Shredder
Tech Solution TS-4500 Shredder Logo
929 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
