Question about E-Machines (T2958) PC Desktop
BootMGR is missing Ctrl +Alt+Delete to restart no change.. continues with the same request.. Computer is a Emachines laptop,  type : AMD Athlon (tm) Processor 265e
    Master:
  • 633 Answers
You will have to repair your operating system or do a complete system recovery.
Posted on May 31, 2010
Toshiba satellite l500 bootmgr missing.
please calm down. do the follow steps.
Restart HOLD the CTRL key +f11 or f12 Depend of your model, mark., and go to restore the factory default and ready.
If doesnot work. restart again HOLD the CTRL key+f8 and use the last o.s was working and ready.
God bless you
Jul 06, 2013 | Toshiba Satellite L500 Series Notebook
Bootmgr is missing
Step 1:
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. make sure there are no disks in cd floppy usb drives Test all power and data leads that attach to your hard drive IDE,SATA the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat ribbon 40 pin IDE it will be the fist to fail Make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs Data and Power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error. also make sure you have set it boot from you hard drive in BIOS Restart your computer and enter BIOS mode. On most computers this is done by pressing the Delete ot F2 key but will vary depending on your computers bios other keys Acer: - Ctrl+Alt+Esc , ALR PC: (F2) or (Ctrl)(Alt)Esc) , Award BIOS: (Del) or (Ctrl)(Alt)(Esc).
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on. Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it. Once you've selected your desired options, continue to boot.
Feb 15, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
BOOTMGR IS MISSING
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on. Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it. Once you've selected your desired options, continue to boot. or The solutions might be very simply... remove your hard-disk and attached to other PC or laptop as an external hard-disk. When it is detected, go to my computer, right-click, untick that (stupid) option, immediately you see the message uncompressing and its done. Put your hard-disk back in to your machine its ready.. w7 insert your OS CD
go to DOS window and type in your OS driver (usualy C:/
type in bootrec /FixMbr
then type in bootrec /fixboot
then type in bootrec /rebuildbcd
then type in exit
restart your computer
it will work 100% only if you prompt at the same order Hope this helps.
Dec 15, 2012 | Western Digital HDD WD5000AAKX 500GB SATA...
Cd no boot record
Hope this helps.
Nov 19, 2012 | Computers & Internet
Solusi untuk BOOTMGR is missing pada acer aspire one happy2 N578Q
This sounds like a hard drive failure, try your recovery disc if available, if no change! have the hardware checked for possible replacement.
Oct 26, 2012 | Computers & Internet
What do you do if you pressed f8 on your load screen to go to the menu to choose a different mode like repair mode or safe mode and so on and when it says intalizing partaition or something you take your...
It sounds like you unplugged it as it might of been rewriting the boot up files. If you have the recovery CD for your laptop still you can go recover it but using the CD and selecting the repair option. Make sure not to select the format part though.
Nov 18, 2010 | Computers & Internet
Hi . Iam ASHOK . my Laptop hava some problem (BOOTMGR IS MISSING PRESS Ctrl+Alt+Delete .) my laptop configuration is intel 3i Pro, Hdd 500 gb , Ram 4gb , OS is Windows 7 . place help me ...............
Hi Good day!! There might be a corrupted files in your windows (BOOTMGR) you will need a windows 7 CD
* Insert your Windows 7 disk into your DVD player and restart your computer.
* The next screen you see should have the Language, Time and Currency and Keyboard boxes.
* In the lower left side there are two options: "What to know before installing Windows" and "Repair your computer."
* Click on "Repair your computer"
* Windows will then try to find the installation directory for Vista or Windows 7, depending on what you have.
* Next up is a screen with a box called Recovery Options. Click the first option, Startup Repair.
* You'll see a Startup Repair box with the message "Startup Repair is checking your system for problems..."
* When it's done, it will prompt you to reboot. If there is more than one problem it may reboot again to continue repairing.
* At this point, you can remove the DVD, reboot and everything should be working.
Thank you for using FixYa
Please accept if my solution helps you!!
Nov 08, 2010 | Dell Computers & Internet
''BOOTMGR is missing'' I can't boot from Windows XP CD
Open cpu cabinet and Refix RAM some times bootable files not load on ram properly so this error comes.
So refix RAM memory clean dust from circuit and RAM .
Also pull cmos cell from motherbord for 5 minutes so all settings are defaults then check.
Aug 01, 2009 | Computers & Internet
Compressed boot manager
Windows Vista includes a new Boot Manager (BootMgr) that replaces the old NT Loader (Ntldr).
If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529
More Info MS KB 927391
This can usually be solved by checking the boot devices, and if no problems found then use Windows Recovery Environment (WinRE) and perform a "Startup Repair".
If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart
This can usually be solved by using Windows Recovery Environment (WinRE) and perform a "Startup Repair". If that fails then use WinRE to enter the "Command Prompt" and execute these commands:
  • compact /U C:\bootmgr
  • compact /U C:\ntldr
Aug 28, 2008 | Computers & Internet
BOOTMGR is missing Press Ctrl+Alt+Del to restart
first u go to bios settings and change first bootdevice cdrom and reboot system u put winxp cd in cd drive
u will see this message
press any key to boot from cd
u press any key
winxp setup start automatically
and repair winxp
som case hardisk partition probelm , that case u will format drive and re install winxp
Jul 12, 2008 | Computers & Internet
E-Machines (T2958) PC Desktop Logo
423 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
