Question about Kenmore Dishwashers
We see white all over the spoons and the bowls and not sparkilig white.
  • 619 Answers
Make sure the water is 120 degrees at start up and also that the jet dry dispenser has jet dry. This aids in the clean rinse and spotting on dishes during wash, but most importaant is the water temp. Must be 120 at start up or you get an almost totally cold water wash.
Posted on Jun 02, 2010
I have a new bag of granulated sugar. It is rock hard. How do I soften it?
hi Diane.
  1. Place the sugar into a heavy-duty plastic food storage bag. ...
  2. Use the flat side of a meat tenderizing hammer or a rolling pin and pound the bag until the pieces are broken into chunks.
  3. Place the chunks of sugar into the bowl of a food processor. ...
  4. Pour the sugar into an airtight container.
  5. How do you make white sugar soft again?
    Here is an easy way to make hardened granulated sugar soft again -- Preheat oven to lowest temperature, 150-200 degrees. Remove sugar from the package andput in an ovenproof container that will hold the sugar. Place in the warm oven for approximately 15 minutes. Tap sugar with a spoon.
Dec 01, 2017 | Garden
Tip
Microwave cleaning
<span>Place a bowl of water in the microwave (with a non-metal object such as a wooden spoon or stir stick in the water*) and heat for 3 - 5 minutes, depending how hard the crud is really stuck on. When microwave stops, keep the door closed to give the moisture and steam the heated bowl of water generated to have time to work. Remove bowl (careful, it's hot) and take a moist, warm cloth to the inside of the microwave. The crud bits should wipe off easily</span>
on Apr 02, 2011 | Microwave Ovens
How do I defrost my 10.0 cu. ft. top freezer igloo refrigator
you have to defrost the freezer the old fashion way...which means it does not do it on its own....you have to shut down the refrigerator in order for it to start melting...and then sop up any water with towels or bowls....key is to never let it get full of snow, so it's easier to do.....another way to defrost it, which I do...is to take a wooden spoon, never metal....and just scrape out the layers of snow that has formed into a bowl as you scrape, put the bowl inside and just scrape it into it.......if you do that once a month, it should keep the snow from too much buildup....I love my IGLOO it's perfect for just me and my condo....and I just redid my kitchen.....however after 2 years now, it's not cooling too well, which I have read other comments that this happens...
Oct 15, 2014 | Igloo Cooler Igloo - 10.0 Cu. Ft....
Im looking for a receipe for bannana bread
Make Delicious Homemade Banana Bread
Cooking your own banana bread from home is a relatively straightforward thing to do, although it does require a couple of moderately advanced techniques such as creaming butter by hand and folding ingredients together.
BBC Food states that you can prepare your banana bread in under 30 minutes, while cooking time lasts between 30 minutes to an hour in order to produce a delicious loaf of homemade banana bread.
Preheat the oven to 350 F.
Sift your flour, bicarbonate of soda and salt through a sieve and into one of the two mixing bowls, ensuring that you eliminate all clumps and are left with a fine powder in the bowl.
Allow your butter to reach room temperature before creaming the butter and sugar together in the other mixing bowl.
Swirl the wooden spoon in a circular motion to beat the butter and sugar into one another for at least a minute.
The creaming process is finished once you are left with a light and fluffy, even mixture.
Crack open both eggs and add them into the creamed butter and sugar.
Peel all four bananas and lay them flat on a chopping board before mashing them into a pulp using the potato masher.
Add the mashed banana into the mixing bowl along with the buttermilk and vanilla.
Mix these ingredients together using the wooden spoon before adding the flour, bicarbonate of soda and salt from the other mixing bowl.
Fold the contents of the bowl using the large metal spoon.
Many chefs use a figure of eight movement, cutting through the surface of the liquid with the leading edge of the spoon remember that the objective is to keep a much air in the mixture as possible, so you should look to turn over the spoon as you complete figure of eight motions, thus replicating a folding motion.
Grease the loaf tin using a small amount of butter or oil, as this will prevent your banana bread from sticking to the tin after you have baked it.
Pour in the ingredients from the mixing bowl, taking care not to spill any or make a mess.
Wait for the liquid to level off so you have a flat, even surface and insert into the oven to bake for approximately 1 hour.
Remove your banana bread from the oven when it has risen and turned a golden brown color. Allow the bread to cool in the tin for 2 minutes before turning it out onto a wire rack and allowing to stand until cool.
Aug 12, 2013 | Computers & Internet
Should knives/forks/spoons be loaded with blades, tines,bowls down or up in dishwasher? When ready to load knives/forks/spoons in the dishwasher, should you load the utensils with the handles at the...
I always put the handles down in hope of the spray hitting the business end better.
I'm sure there are arguments for handle up too, but I put the handles down.
lp
Jan 08, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
Work bowl stuck.
Hello. It will release. Just use a wooden spoon wrapped in a towel to gently tap on the handle until it moves and releases. J.
Jul 05, 2010 | Cuisinart DLC-2009CHB 9 Cups Food...
MOWER IS HARD TO START
  1. g and wire aSounds like a dirty carb. Drop the bowl ,after shutting off gas, and and with about a2 foot piece of hose, blow up the center tube on the carb.Replace the bowl. Remove the plug and pour about a table spoon of gas in plug hole. Replace plug and plug wire. Try to start it.
Apr 30, 2010 | Toro Lawn Mower With Toro Power Tools
I used the shredding blade and now can't get the inside spindle to pop off or the bowl. It will still work if I put the blade in and turn it on. How can I get the spindle and bowl loose?
I posted about this somewhere else. Sounds simple but it worked for me. Give the spindle a good whack with a wooden spoon all the way around and it will come loose.
Sep 01, 2009 | KitchenAid KFP750 Food Processor
Stripped beater gear
It is terminal. This is the fatal design flaw of these mixers. The gears are made of soft plastic and strip easily. Even the gear housing is plastic that is either glued or melted together to make it unserviceable. I have never suceeded in finding the part from either Sunbeam or one of the many appliance repair places on the web (who charge the cost of a new mixer for repair). Sunbeam does not repair them; if it is determined to have malfunctioned due to quality or design while under warranty, it is simply replaced with a new one. I had mine replaced under warranty twice, each time they sent me a new one complete with extra bowls and beaters. Now I have three sets of bowls and beaters and no functioning mixer.
May 25, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Dishwashers Logo
85 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
