Question about Weber Genesis Silver B Grill
Noise coming from tank
When I turn on the gas and try to light grill a noise comes from the tank. What do I do to correct this problem? Thankyou.
  • 8,404 Answers
Yours is a DOT type tank (portable not fixed)
What is the noise? Is it gas coming from the tank to the burner? Hissssssssssss Are you properly connected? Is this a OPD equipped tank? Is there a hole or crack in the hose letting the gas out before it gets to the burner?
Do not examine it with a match!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If your tank is very old, you may not have a OPD equipped tank (is the handle three sided?) Yes = OPD No = old style. Only OPD equipped tanks can be filled in the USA. Old style tanks can leak if not properly connected.
New OPD tanks will not let gas out unless there is something properly connected to the tank. You are NOT fooling around with the 80% valve are you? If you are - STOP. (small screw on the right hand side of the connection fitting.)
If there is any fault in the equipment, connector, regularor, hose or any fitting - get it fixed! One gallon of liquid propane becomes more than 350 cubic feet of highly combustible gas. If it leaks out and gets ignited, at least it will be quick! Dont become the entertainment!
Any parts that are questionable ... replace them!
Please seek additional assistance from your professional propane supplier.
Thanks for your interest in FixYa.com
Posted on May 31, 2010
My Grand Turbo Grill will not light. I can hear the gas coming out of the tank but it will not light.
Carol, to solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling. Thanks for choosing FixYa.
Aug 03, 2011 | Barbeques Galore 52-inch Grand Turbo...
After changing gas tank - gas isn't coming out. grill not fireing up.
Vincent, this is caused in part by the Overfill Protection Device (OPD) valve in the tank head and the way the tank was turned ON.
To solve this problem, do the following:
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Jul 19, 2011 | Weber Grilling
My grill has 4 burners. When I light the first one, everything is fine. When I go to light the second one, it sounds like it is cutting off the gas and it won't light. You can hear the gas coming out...
The problem you're having is a result of the gas tank & the grill's gas regulator. However, in most cases, it's solvable if you do the following.
1. Turn the gas tank valve OFF & disconnect the hose from the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow) .
4. Once the valve is full open, light the burner farthest from the tank first and set it on HIGH.
Does the fame height look correct? If so, light the remaining burners the exact same way.
Did all the burners light and the flame heights look correct? Is so, you solved the problem.
Remember to always open the tank valve Very, Very Slowly.
If the above did not solve the problem, you will need to replace the Hose/Regulator Assembly. It runs about $30.00 at hardware stores or home centers that sell grills & grill accessories. Take you old one with you for comparison purposes.
Jul 07, 2011 | Amana Grilling
I have a full tank of gas and all valves are open but no gas comes out.Can you tell me what is wrong
Yes, you have a problem with the OPD Valve in the gas tank, but it is solvable.
First, tunr the tank valve OFF. Disconnect the hose from the tank and wait 5 minutes. In the meantime, turn on all the burners to the highest setting for 1 minute and turn them OFF. After 5 minutes has elapsed connect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open light the burner that's farthest from the LP tank first and turn it to high. Does the flame height look correct? If so, light the remaining burners the same way. Do all the flame heights look correct? If so, you solved the problem. Just remember to always turn the tank valve ON very, very slowly.
If the above didn't solve the problem, you will need to replace the grill's hose/regulator assembly. You can purchase one at any home center or hardware store, that sell gas grills and accessories. Just take you old one with you for comparison purposes.
Hope this helped you to solve the problem. Please let me know and Happy Grilling!!
May 13, 2011 | Weber Genesis Silver B Grill
Hi.. have a 300 series weber we bought only last year.. I cannot get the burners to come on together.. I can manually light the inner one but as soon as I try and manually light the outer one... it will...
More than likely, the grill's regulator is malfunctioning. To solve this, turn the LP Gas Tank Valve OFF and disconnect the hose. Turn the grill burners ON, wait 2 minutes and turn them OFF. Reconnect the hose to tank and open the tank valve VERY, VERY SLOWLY (Slow motion, slow) Once the valve is open all the way, light the inner burner first and turn it to the highest setting. Does the flame height look correct? If so, light the outer burner and turn to HIGH. Do both flame heights now look correct? If so, you solved the problem.
If you are using an insert-able gas canister, instead of a 20Lb LPG Gas tank, do the same thing as above, except remove the canister. Since there will be no hose/regulator assembly involved.
To provide further assistance, in case you have misplaced your Owners Manual, I have included a link to it that you can download and print for future reference, if you like.
http://help.weber.com/manuals/ducane/2009%20Manuals%20pdf/Affinity_3100_4100_LP_OwnersManual_27010331_101508.pdf
May 10, 2011 | Weber Q Grill
Hi, my grill will not start. I press the ignitor button and I can hear the clicking which sounds like it's coming from the side burner area not the main burners. No lighting though, any ideas? I replaced...
Ronald, I doubt that the gas regulator has much to do with this problem, unless the tank valve is turned OFF or the gas tank is empty Have you tried match lighting the burners, to determine if you're getting gas to them? Also, check the spark ignitors at each burned for a grease build up. using a cotton ball and alcohol clean each ignitor tip.
If you've checked all of the above and you're now getting a spark at each burner, but little or no gas to the main burners, do the following:
Turn the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow). Once the tank valve is fully open, light the burner farthest from the tank first and turn the burner to the highest setting. Does the flame height look correct? If so, light the remaining burner(s) the same way. Does their flame height look correct? If so, you solved the problem. Remember to always turn the tank valve ON very, very slowly.
Happy Grilling!!
Apr 27, 2011 | Kenmore 632 sq. in. 16324
Grill does not get hot. I have a fresh bottle of propane. Hose is not kinked. Grill is maybe 6 - 10 years old.
hi,
When a new or newly filled propane tank is attached to your gas grill, the OPD is usually at its maximum limit position above a tank filled to capacity. Propane may come through the valve too strongly due to the additional pressure of being full and the OPD displacement. The propane tank goes into check and limits gas flow when too much pressure hits the valve. Some grill manufacturers provide instructions for this in the users manuals but most people do not read the manual. Many grillers believe replacement parts are needed and burners, ignitors and regulators get replaced without reason. Depending on how efficient the grill is operating, some grills attached to a tank in check will not ignite and others will light but cannot reach cooking temperatures because the tank has limited the amount of propane released. Sometimes the food will be unable to exceed 200 degrees in temperature because the propane tank is in check.
Gas grill replacement parts are available and are sometimes necessary, low or no gas flow indicates a different typr of repair. Most grillers accept instructions and the problem is corrected in minutes -- but believe it or not I have had a few insist on purchasing replacement parts.
How do I fix grill?
To reset the check valve and get back to cooking on your gas barbecue grill, first
turn everything off. Turn off the grill, the rotisserie, the side burner and the LP gas cylinder tank. Once everything is turned off disconnect the propane tank from the gas grill regulator by unscrewing it or pulling the quick-release on older or retro-fitted propane cylinders. Now turn the grill on. I know, it is dis-connected from the gas tank but we want to ensure that the pressure in the gas lines or any gas in the burners is released. Leave all grill burners in the on position for 3 - 5 minutes before turning them off. Make sure. Most gas grill valves must be pushed in to turn them and if turning is attempted without pushing the knob, they will not turn to the "on" position. With the grill, et al turned off reconnect the propane tank and slowly turn the hand wheel to the open position.
Slowly. The trick here is to turn the hand wheel slowly. Propane in a new or very full tank will be under more pressure, especially with the OPD floating in position. The extra pressure will come through the tank valve stronger. Turn the gas tank slowly allowing small increments of propane to enter the grill.
Once this is complete, you should be able to turn the grill on high and ignite your gas grill burner. Your cooking heat should be back to normal and cooking times decreased. If the problem persists, try this process again to make sure you followed every step. The check valve exists to save your life if there is a leak in any of the gas fittings. Constant check valve issues could imply a gas leak and a visit from your local gas grill service technician may be necessary.
To find a leak, turn the grill valves to the off position and the gas tank valve to the full on position. This should pressurize the gas line. Spray soapy water on all the fittings and look for bubbles just like checking for the leak in a flat tire.
Do not attempt to correct a gas leak on your own. While a check valve error when your gas grill will not get hot or will not ignite is a user education error and an issue corrected by learning about your propane tank, a gas leak should be corrected by a licensed gas service technician. When you are grilling, turn the propane tank on first and then turn on your grill. When you are done cooking, turn the gas tank off first and then turn off the grill valves. The process releases the pressure in the gas grill hose and manifold which allows the gas tank to release pressure by filling these lines. Read the safety features of your gas grill, clean it when necessary and replace used and failing parts. Aside from that be safe, eat well and have fun.
thanks.
Jun 15, 2010 | Weber Genesis Silver B Grill
There is a humming noise coming out of the bbq when i turn the gas on
This noise is a cause of restricted gas flow. Try disconnecting tank and reconnecting. Open valve slowly, see if this solves problem. If problem still exists then problem could be with tank or regulator. Try tank first, if this doesn't solve problem call weber and your regulator should be under warranty and be replaced for free.
Jun 13, 2010 | Weber Genesis Silver C Grill
There is a high pitch that people over approx age 30 cannot detect. My son and daughter complained of a high pitched noise coming from our gas grill, but I could hear nothing. I turned the gas tank off,...
What they are hearing is the regulator. There is a diaphragm in the regulator that is vibrating due to the rush of gas flowing through it. This is easily corrected. First, the next time you light the grill, turn the tank valve only one quarter to one half of a turn and light the grill, once the grill is lit, if you have trouble bringing the grill to the temperature you want, you can open the tank valve more and the noise shouldn't start. The reason the noise won't start then is because by that time, the regulator's diaphragm is at the temperature of the gas flowing through it and, subsequently, will not vibrate. If the noise starts again, you can go to just about any home improvement store and get a replacement regulator.
Nov 18, 2009 | Kenmore 16322
Gas does not flow when you turn on gas knob when you turn on the gas valve on the tank and then turn the knob for gas to get to the grill, just before you hit the ignighter no gas comes out
make sure there isn't a designated burner for lighting. sometimes there will only be 1 burner the grill will light. start with all them off, turn on the tank. the grill will have a little picture of a flame next to the burner knob. turn it to high and try lighting
Jul 15, 2009 | Weber Grilling
Weber Genesis Silver B Grill Logo
244 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
