Question about Maytag Atlantis MDE7400AY Electric Dryer
Overload roommate overloaded my maytag atlantis electric and now i hear it starting but it doesnt turn at all, is this just a belt or plastic gear? if so, is it easily fixed(can i fix it)?
    Scholar:
  • 178 Answers
For the most part, yes this is an easy fix depending on your model number. Contact me back with your model number and I will be able to further assist you.
Posted on Apr 09, 2008
  • Robert Fawbush Apr 09, 2008
    I failed to see the model number on your post, I am sorry for that. Yes, if indeed it is the belt, you can fix it. The belt is a maytag specific so a generic belt will not work. I have found a belt in 9 US warehouses in multiple quantities for 21.87 before shipping. If you would like more information, please e-mail me at robert_fawbush@yahoo.com and I'll be happy to assist you.
My dryer starts but doesnt turn?
check the belt, it could have slipped off the drum or broken,, they are fairly easy to replace , check this link it will give you an idea of how its done, http://repair2000.com/wpoolbelt.htm
Jun 09, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis washer. Washer makes noise that approaches grinding, and the agitator doesn't spin. Rather, isn't connected to the motor. Spins semi-freely by hand, with a rough motion and noise
Your unit is gear driven and is contained in a mechanism enclosure.The roughness your feeling when turning it are the worn-out gears.One cause is it might have ran out or dried out of gear lubricant.The motor drives a belt to run the gears so the motors are running fine.Your gear box is the problem.
Dec 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis dryer drum not spinning. Light works, there is a hum from the timer, belts are good, drum spins freely, thermal fuse is good. Need to know what would be wrong with the dryer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 27, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
My maytag atlantis mav6520aww just stopping working. It fills at the correct water level and then just stops nothing else, Help!!! Can't determine if the motor or the belt both looks fine.
The possible problem here is the plastic gearing that connects the transmission to the motor to start the agitation has broken and will need to be replaced. If you forward the machine and it drains and fills properly then that will be you problem. This peice connects the motor as I said above to the transmission to start the cycle. This part sits between the motor and the tub itself and is a monster to replace yourself however, it shouldnt cost an arm and leg to have an appliance tech replace it.
Hope this helped
Dave
Feb 19, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6250AWW won't rinse or spin?
clean motor rollers(belt may be slipping)
9vopy...paste)
Aug 31, 2009 | Maytag Atlantis MAV7260B Top Load Washer
Dryer belt snapped bought new one and will not reach the pulley by a 1/2 inch this is a maytag dryer thought these belts were all the same length are they not ....
make sure the belt is in the groove on back of drum for belt then run belt from left side of drum over and around pulley on motor shaft going clockwise then continue around pulley and run belt toward belt tension pulley the one with the spring on it go counterclockwise around it at this point you will have to pull up on tension pulley to get belt on then realease that should take care of it ed
Nov 01, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Dryer won't run
Maytag Atlantis Series MDE6400AYW --
Current is good, brand new power cord, drum light comes on --
When I turn the timer, I can hear it clicking, but nothing else works.
Aug 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Why is Maytag Atlantis is not drying like it use to?
Nov 12, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis doesnt run
change the copasitator this tells the machine to engage the motor
Oct 24, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
59 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
