Question about Craftsman Garden
The rear bagger lid springs became detached and not sure how/where to re-attach them. It won't stay closed down to allow side discharging or closed up to hold the bag and catch the grass clippings.
  • 246 Answers
SOURCE: Grass clippings won't go into bag
Hello steveacosta:
Check the Blade. If the Lift Area Behind the Sharpened Area of the Blade is Worn, then you will have the Problem you Described.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 16, 2009
  • 512 Answers
SOURCE: Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Posted on Aug 22, 2009
vincob
  • 718 Answers
SOURCE: mtd bagger not bagging
Open the door to the bagger chute when you attach the bag.
Posted on Sep 26, 2009
  • 2926 Answers
SOURCE: to mulch my grass clippings, do I have to use the
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
Posted on Jun 10, 2010
  • 14585 Answers
SOURCE: Spring on wiper arm became detached. How do you
There is a little arm on the wiper that the spring goes on if it missing you need a new arm. if it still ther you can get it on with needle nose pliers. you will have to take the arm off good luck
Posted on Jun 18, 2010
Red light inside the freezer part stay on for my side by side Kenmore refrigerator
Hello William;
My name is Peter. I am a retired field service refrigeration technician.
The, 'Red' light is a infra red light. This light assembly on the right hand side of your freezer is the transmitter.
Directly across is the receiver. On the receiver is a spring loaded plastic flapper.
This is a safety device for your ice maker. When the freezer door is closed, the flapper is closed, allowing the infra red transmitter to complete the signal to the receiver. This allows the ice maker to discharge ice cubes. When the door is open the signal is broken, the flapper springs out blocking the circuit signal, and the ice maker will not discharge ice cubes.
There is a On/Off switch on the red transmitter. I do not know why you would want to turn it off. If you turn it off and the transmitter stays on then you have to replace both the transmitter and receiver.
Nov 11, 2014 | Kenmore Refrigerators
Attach bagger
ive got a JD 180 .with a bagger on it if you have the factory bagger
1st bolt bracket to back right hand side of tractor holes should allready be there next assemble bagger top to tractor bracket , hang collection bags (two) from top of bracket (open top to access) then assemble diverter tube all together three sections , snap end (wide) into bagger (no bolts needed) then fold back safety discharge cover on deck all the way snap the inlet adaptor into hole left by this (perfect fit) and last stretch rubber bungee up to deck wheel strut and place clip thru small moon clip there, now you willl need to replace your deck blades with the High Lift type (mulch) avail still from JD (theres a extra wing on back of it) this makes more air to scoot grass up the chute if not your gonna have a lot of cloggs
Oct 30, 2014 | John Deere Original 130 160 165 175 180...
How to install a Husqvarna leaf bagger
The bagger installs by using the supplied bracket on the rear of the tractor. Mount the frame of the bagger onto the bracket. then connect the discharge tubes using the spring connecters. Flip open the lid and slide the bags into the frame.
Sep 04, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Why does the rear bagger plug up way before it's full
Wet grass will do this. If the bagger is partially plugged up with old grass this will do it also.
May 27, 2014 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Toro Lawn Mower
tis not a toro but they all go by the same principle.
hope this helps
https://www.youtube.com/watch?v=wYaKYwVUW0c
Jan 22, 2018 | Garden
Torro Lawn Mower side discharge spring
There are 2 bolts with nuts that mount the spring/door assembly to the mower deck.
Jul 08, 2013 | Garden
Harley bag lid loose
Hi Anonymous, call, take a ride or trailer your bike over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary/possible and offer professional advice and assistance concerning your issue. Good luck have a nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 29, 2012 | Harley Davidson Motorcycles
Deep fryer
If the lid will not stay open, there should be a small spring in the hinge. I am not sure of your model, But some have a safety interlock that will not allow operation with the lid open. These usually have a feature of raising and lowering the basket with the lid closed like some chemistry experiment!
What's wrong with a manual wire basket?
If the spring is not fitted correctly, or missing, it's fiddly but not impossible to replace.
Oct 28, 2008 | Kitchen Appliances - Others
Lexmark Optra T612
The broken part is called the bell crank arm part number 56P1228 this is very common. If the printer isn't recognising your tray, remove it and check the little plastic fingers on the left side (half way down the tray) and the metal springs in the printer (left side) which the tray pushes on to.
Aug 04, 2008 | Lexmark Optra T612n Laser Printer
Garden Logo
98 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
