Question about Sharp Notevision PG-B10S Multimedia Projector
The letters are grainy using the data projector
Do you have a solution for me to try resolve this issue.
  • 75 Answers
Try changing your setting s on your computer to match the resolution to your projector. Change display settings to 800x600, 1024x768, etc. with your mouse right click on your screen, click properties, at the display properties dialogue box click the settings tab you should see the screen resolution.
Posted on Jun 05, 2010
INFOCUS IN102 PROJECTOR LIGHT BLINIKING
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Aug 02, 2017 | Cell Phones
Z3 projector.3 years old. Blue tinge in one corner of projected picture. Grainy picture on dark scenes.
There may be some problem with your picture tube else try this that looks like retrace lines. Anyway, you should try to adjust screen pot not focus pot. Make sure you are turning blue screen pot (there are 3 focus pots and 3 screen pots) and do it slowly. If you turn it too much, it will affect your grayscale
Jun 23, 2008 | Televison & Video
I have a InFocus in 1503 projector and the lamp will not come on. I know the lamp is good because i tried it in a like projector and it works. At initial turn on it looks like its going through the start...
First. try to update de software. In this model the update is very important. The lates version is v1.03.
  • Resolves intermittant fan control variations (audible noise) that may cause premature shutdown.
  • Resolves custom picture settings retention issue when changing sources
  • Fixes 'magnify' - so that when exiting this frature the image returns to it's original size and position
  • Resolves 480i/480p locking issues when Aspect Ratio is set to Auto
  • Aug 14, 2013 | InFocus Office Equipment & Supplies
    I can not initiliaze wd 160 Gb disk! I just delete all from disk and whan put in USB, power Ok but no name in my computer?
    try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery software to recover your files.
    http://www.asoftech.com/adr/
    Aug 31, 2011 | Western Digital Passport 320GB External...
    I have a MacBook Pro and a XR-30s sharp projector. When using the DVI port on the Mac to DVI-D on the projector the picture turn grainie. WHY? However, when I disconnect the cable, the pix clears up on the...
    It is probably mirroring the screens on your MacBook and the projector. If you want different resolutions and things on each screen, go to the Apple menu, System Preferences, Displays, Arrangement and uncheck the "Mirror Displays" checkbox.
    Apr 22, 2009 | Sharp XR-30S Projector
    You had replied to a question that I asked.
    This could be something as simple as a poor solder connection on the board. If you can solder, resolder any connection on any of the boards that appears to be grainy or has rings. That is the first step. That may resolve the problem. If not, try to determine whether or not there is a pattern to the appearance of the problem and post that info here.
    Thanks,
    Dan
    Sep 09, 2008 | Televison & Video
    Image Problems - Grainy Black and White Image
    Hello Carmen,
    Well this can usually be caused by one of two things.
    #1 the main board has failed and needs to be replaced.
    #2 The firmware's flash data has been corrupted and need to be re-flashed. Both of these solutions will need to be performed by an authorized technician.
    I have parts for these projectors if you want to learn more regarding this you can contact me at,
    dennis@sagertronics.com
    Take Care!
    Aug 09, 2008 | InFocus X1 Multimedia Projector
    LP600 - Grainy picture, very poor quality
    Single chip DLP projectors use a spinning color wheel between the lamp and the DMD (mirror chip) to produce colors. If the wheel rotation/synchronization is disturbed, colors will not be displayed correctly.
    In my case it looks like the wheel became un-synchronized, probably because the projector was dusty/dirty inside (a light senor is used to detect the wheel position), resulting in a grainy, slightly flickering image.
    I simply blew out the components with a can of 'Dust-off' and, using a small tool, rotated the color wheel by hand to make sue it wasn't rubbing or jammed.
    I reassembled & started the projector and the image was back to normal.
    Jul 19, 2008 | InFocus LP 600 Multimedia Projector
    I've bought a USB 3RCA data cable to project video from my Laptop to me TV/projector. However it doesn't work, and no signal appears to be received by either TV or Projectors... USB 3RCA Cable from PC...
    i hope that is a USB driver issue when u plug your device does your computer detect any usb device and then its says unknown/unrecoginzed device. You have to check the cables first then you download USB2.0 driver install it inyour computer andl aslo try to connect the device in another port also put the the driver cd for the TV/projector
    Jul 02, 2008 | Computers & Internet
    Sharp Notevision PG-B10S Multimedia Projector Logo
    98 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
