Question about Micro Innovations PD960P Mouse
How do I reset my PD960P? It has new out of the
How do I reset my PD960P? It has new "out of the pack" batteries but will not respond. The red light is on the receiver but not the mouse.
Thank You
  • 112 Answers
You need to connect it by holding the the button down on the receiver and mouse, and you need to install the driver for it, if you can
Posted on Jun 20, 2010
Dewalt de0245
These de0245 chargers are designed to detect certain problems that can arise with battery packs which would be indicated by the red light flashing at a fast rate.
If this occurs, re-insert battery pack. If problem persists, try a different battery pack to determine if the charger is OK. If the new battery charges correctly, then the original pack is defective and should be returned to a service centre for recycling.
If the new battery pack gives the same trouble indication as the original, have the charger tested at an Authorised Service Centre.
If you need new battery for this tools
Mar 23, 2014 | Drills
Pushed reset button and will not respond. Red on light stays on
11/6/12
Copy following link for Utilitec LW60418 timer.
Same as Westek TMDW10, and Stanley 30418
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer is reset with one-button.
Unlike some timers that require 2 button push.
Push in reset button firmly with paper clip, and hold for several seconds. Repeat.
This action will clear timer memory.
If reset does not restore functionality, then timer could be bad.
This timer has 1 year limited warranty.
Suggest buying new timer at Lowes, and returning defect timer in new package.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 05, 2012 | Intermatic Inc. ST01C Digital In-Wall...
My epson camera cp-800s showing red light & i can't take photo
New batteries? Fresh re-charge? Fresh battery pack if not responding to recharge? Is charger OK?
Check card is inserted properly?
Dropped it recently or ever?
Sep 24, 2011 | Epson PhotoPC 800 Digital Camera
Whenever I put new batteries into my Canon Powershot A480, I get the same thing - I get the 'Low Battery' red flashing light. And Then as I go to take a picture it shuts off and says ; Change The Batties....
I've got the same problem with 2 A 480 canon. I put in NiMH batteries and they work fine. If you put in slightly drained used batteries they work!! Nimh batteries are 1.2 volts and Alkaline are 1.5 volts. There is definitly a problem with this camera. I measured the voltages of brand new batteries 1.51 volts each and they didn't work. I put in some old batteries 1.4 and 1.42 volts and they worked fine.
Dec 17, 2010 | Canon PowerShot A480 Digital Camera
New leapster explorer, it freezes will not respond to pwr off or on have to pull out battery pack for it to reset do you know what hrs call center is open? been on hold for 15-20 min
I also had this issue. I had gotten two, one for each child. I took the battery pack from the one that was working and put it on the one that did not. That still did not work. When I put on the original back on it started to work. Maybe the connection was bad? Maybe there is an identifier on battery pack that got reset?
Dec 06, 2010 | Leapster Learning System
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
R707 locked in the video mode
remove battery pack and memory card then replace should work.
May 05, 2008 | HP Photosmart R707 Digital Camera
Ipaq rx3115 frozen
Red LED light means a major problem at the charging of the battery.
You have several options to repair it:
1. Leave several hours the PDA with not battery and unplugged from the AC power adapter, then put the battery and leave charging it.
It's more likely that the red light will appears again, but leave plugged it. Sometimes will start charging and blinking with orange color after 30 minutes or so. After that, it will work normally.
2. Use other good working battery to test it.
3. If the above two steps fail, then there is a good chance that the mainboard has a problem, and needs to be fixed or replaced.
Best regards,
Jan 25, 2008 | HP iPAQ RX3115 Pocket PC
Micro Innovations PD960P Mouse Logo
65 people viewed this question
Top Micro Innovations Computers & Internet Experts
micky dee
Alun Cox
Are you a Micro Innovations Computer and Internet Expert? Answer questions, earn points and help others
