Question about Haier Heating & Cooling
What is the proper way to braze the copper lines for a new residental condensing unit and fan coil
  • witt7229 May 31, 2010
    thank you very much
    President:
  • 949 Answers
Brazing refrigerant lines that are copper to copper should be done by first sizing the tubing. For example if you are brazing 1/2" to 1/2" lines together you need to swag (expand) one end with a swagging tool. This will allow them to fit together tight.
Once the joints are sized they must be cleaned, be sure to use refrigeration sanding cloth so there are no oils or contaminates.
If you are brazing copper to copper use 15% silver solder (silfos stick) and no flux. If you run into a joint that is steel to copper use 45% silver solder and flux.
Let me know if you have more questions.
Posted on May 31, 2010
    do ineed to fill the lines with anything
  • Philip May 31, 2010
    You should not need to fill the lines. Once the brazing is done you will need to vacuum the lines to remove any moisture or non condensables
I punctured a small copper line on the outside coil of attic unit. All coolant leaked out. How much and how hard to repair line?
the line can be soldered brazed or replaced ---how hard depends on access to it ---unit vacuumed then pressurized with freon [unknown size of unit ]--then tested --estimate will vary [would need to see access and amount of damage as well as age and size ]--can be anything from 250 up check with hvac companies in your area for estimate
Oct 03, 2016 | Heating & Cooling
Goodman split type system, model MSG12CRN1W Want
Hi, this is very easy to find out. The out door unit has 2- copper lines coming out of it. A small one on the unit, 3/8" and a large one either a 3/4" or 7/8" depending on the size.2- rolls of copper called the line set are silver brazed into the fittings coming out of the outdoor unit of the same size and uncoiled and ran to the indoor evaporator coil. Again, one is brazed into the smaller open fitting, 3/8" and the other into the larger of the two. There is only one way to install these as the open fittings are made for you to put your lines into at the factory and silver braze them. They could have cut a line and did there own design, but that would be wrong. What kind of problems are you having? I have seen installers add to many joints to connect to and they would be in the way of the panels going on right, but its pretty much cut and dry, a larger suction line at each end, and a smaller liquid/discharge line on both ends. Please let me know the problem?
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Oct 01, 2010 | Amana Heating & Cooling
Hello, My condensing unit (LG-LMU245HV) and my wall unit (LG-LMN185HV) are brand new and were installed just one month ago. Everything has been running fine but now all of a sudden now the air coming...
Hi, when the copper lines at the condensing unit, the larger of the 2- start to form ice, you have a freon leak. The unit is new, so I would expect the leak to be at one of the welded/brazed joints. What will happen, is the indoor unit, the evaporator coil will start to ice over and block off all air flow through through the coil. I hate to tell you this, you will need to call the installer out to do a leak check on the unit. They will then need to pump it down, braze the leak with sil-phos, or silver solder and recharge the unit. This is the problem, I see this a lot on new units. Someone forgot to do a leak check on it. Being only a month old, it has to have a warranty on it, shouldn't cost you a dime, but this is the problem, indeed!! Please keep me updated on this and get them out there. It will never cool until they fix the leak and recharge it. Please don't forget to rate me on this, I know you will be kind. Keep me posted and you can contact me by my user name below. Thank you Zeke! You still have freon in the unit, just low enough to start the suction line outside to start to ice and loose your cooling.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 06, 2010 | Heating & Cooling
Side of freezer seems warm
Hi!!
Don't worry about the line, it is supposed to be the way it is. If you are talking about the condenser coil, located on the back bottom part of the unit, with a small fan in front of it, yes, it is supposed to be hot.
The condenser job is to disipate the heat absorbed by the evaporator (the coil inside the freezer). Make sure the condenser is clean and condenser fan is working, also, make sure there is air circulating thru the back of the unit to help cooling the condenser.
The noises you hear, are probably the defrost coil melting the ice on the evaporator, this function is on a timer and happens 3 or 4 times a day.
Good Luck!!
Aug 03, 2010 | Woods 247 cu. ft. Upright Freezer FU25
Turn thermostat on, cooling fans kick in, i can feel compressor with my hand moving but no cooling inside freezer or fridg
Hi, you say the fan in the freezer kicks on? You also have a fan located by your compressor and coil which is the condenser fan motor and condenser coil. This fan must also be running when the compressor is on.Make sure that the coil down below is clean on the front of it as it draws air across this coil to keep the internal head pressures down. Check all of these things. The small copper line coming off the compressor, discharge line should be almost hot. The larger of the lines is the suction line and will be very cool, almost condensating . If not, you may have developed a small freon leak which will cause these problems. Make sure that everything I said is working and clean, and if the small motor in the rear bottom is not running, you can get a new one at a appliance parts house and 2 wires will replace it. Do all of this and keep me posted.
Shastalaker7
Jun 15, 2010 | Refrigerators
The weld inside the condenser broke and lost pressure/freon. Seems like this weld given that it is inside the unit should not fail. Will have to patch if we can or replace the entire condenser. It's a...
Hi, all I can say it had to be a poor weld from the factory to fail like that. If the weld joint is easy to get to, you shouldn't have to replace the condenser coil. You will need oxy/act. torches and sil-phos or silver solder with at least 15% in it. If you can do this yourself, you will need the torch, a vac pump, and the skills to braze, to evacuate the system for around 45 minutes, and the gauges to charge it. If its a new unit with the new R-410a, you will need the gauges for that freon due to the high pressures. If its the R-22, you need just the regular type. If the joint is right at the condenser coil, you can remove some of the fins in that area to give you more room. It might appear to be aluminum, but its copper to copper and you should have no problems welding it. Do not use JB weld or any type of epoxy as you are wasting time and money, it will not hold!! This is high pressure in the condenser, and no patch other then a braze will hold. If you heat the area where it came apart, use channel locks to push the copper together. You may need to put a 1/2" coupling over the joint. If you feel you cant get excess to the equipment to do this, you will have to call out someone that has the equipment. If you are able to do this, great. The data plate will tell you the amount of freon to put in. I would weigh the charge in after I made sure the unit holds a vac. If it doesn't, its still leaking. Keep me posted on this and I will help as much as I can from here.
Best of Luck,
Shastalaker7
May 24, 2010 | Heating & Cooling
How to replace evaporator coil on rs267labp?
you will have to have soldering skill with a oxygen acetylene brazing torch.. first remove the coils either cutting the lines or aplying heat to the conection, they will come loose. then position the new coil and braze weld if its copper to copper use silver brazing if its steel to copper, or steel to steel you will have to use bronze rods.. however if the joint shall be aluminum to any other metal you will have to do some research on tha one .. hope to be of help...
Feb 10, 2010 | Samsung 26.0 Cu. Ft. Side-by-Side...
Ice forming on condenser copper tubing GE referigerator
is your drain line plugged up under that coil? another thing to check is if the door asket pinched that wold allow ait to infiltrate into the freeze and freeze up the coil. remember to clean under the unit once a year to keep the unit working properly and not having to struggle to condense the refrigerant. Hopt this solution's work for you and have a Happy New Year.
Jan 05, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Rudd 2 ton 10 S
The small copper line should not be really hot its supposed to be carrying liquid refrigerant which has already had the heat "pressed" out of it by the compressor and carried of by the air flowing over the condenser coil. This could indicate a few things; that your unit is overcharged, you have a mismatched evaporator coil and condenser, an ineffective condenser fan motor or a clogged condenser coil and as a result your compressor is shutting of due to an overload condition from the building heat and back pressure between the compressor outlet and the evaporator inlet.
First make sure your condenser is clean and that adequate air is flowing over the fins of the condenser coil. Then be sure your equipment is a matched system. A indication that your condenser fan motor is not at speed is slow starting a humming sound and excessive heat. In my experience this complaint is generally the result of a bad condenser fan motor that over heats and shuts of after a short period and the build up of heat in the liquid refrigerant line of course trips the compressor overload circuit- which by the way usually takes hours to reset. I hope you've already resolved this, but in case you haven't......
Aug 01, 2008 | Ruud Matching Split Air Conditioner
Coleman ac unit
If this would be worth fixing would depend on how long the unit ran after the tubeing was broken and how long it has been open for to determine if any contaminants were introduced into the system. A good technician would come out and braze the lines back togather, bolt down the condenser, purge the unit with nitrogen, and pull a deep vaccum before recharging the system. If this were done and your system worked fine which should be the case. It would save you the cost of a new condenser.
Jun 10, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
