Question about GE 14.8 cu. ft. / 419 liter Chest Freezer FCM15DPWH
Freezer temp Have a GE Freezer Model FCM15HDPA. Making a different sound then normal (sounds like it is not quite starting). Temp seems not as cold. Any suggestions of problem?
  • 36 Answers
Coolant is leaking (because it is probably old), so you might want to get a repair person to get some more coolant, or you could just buy a new Freezer.
Posted on Apr 25, 2008
Temp display reads 92 (hi temp) but the interior temp is 0.
No. Sounds like the intern temp sensor is bad, missing, or not connected. 92 is probably the max reading it can display. The unit will probably operate continuously, be much to cold, and cost a ton to operate. I assume you bought this from Sears. Call them to replace the freezer. Should be no problem.
Oct 24, 2012 | Kenmore 20.6 cu. ft. Upright Freezer 2809
My magic chef freezer will freeze for a day and then the temperature will increase to 70 degrees. The freezer is just two years old. Is it worth having someone to come out and look at it or is it...
This is a manual defrosting freezer so the most likely cause is the temp control. Sad that is is only 2 years old but the temp control is not working correctly.
It sure sounds like it is running until it cycles off at the "I reached the cold enough" SET TEMP then never starting up again. That start up is controlled by the temp control. Call and make SURE the temp control is called the thermostat!
1-888-775-0202
  • Available 7:30 a.m. to 7:00 p.m. central time, Monday - Friday
  • The Part number is WPF24B-L and the only source is Via this link: http://www.mcappliance.com/partorder.aspx
    List Price $22.95
    Thanks for choosing FixYa.
    Kelly
    Sep 05, 2010 | Magic Chef Chest Freezer MCCF5WBX
    GE TBX21ji Refridgerator/Freezer Factory Icemaker quit making ice
    Normally, when the temp of the icemaker gets to about 14 degrees F, the icemaker goes into the harvest mode, turning on the mold heater and attempting to eject the cubes. When the heater has warmed the mold sufficiently to release the cubes, the ejector can continue and push out the cubes, then the icemaker fills with fresh water to beging to make a batch of ice again. Manually starting the cycle as you have done only allows the cycle to start without the temp sensor seeing the 14 degrees. The mold heating generally takes a couple minutes. If your mold heater or the temp sensor are not working, you will have to replace the icemaker, as they are not available as a repair parts.
    Jul 04, 2009 | Freezers
    After freezer was moved not getting cold
    Unplug the unit and leave it undisturbed for 24 hours. Plug the unit back in again and see if it will come to temp.
    Jun 02, 2009 | Freezers
    Not cold enough. ice on back of freezer but not making cubes
    sounds like you might have a deforst problem or your drain is blocked not allowing the water to drain when the fridge goes into defrost.
    Apr 24, 2009 | Freezers
    Temp alarm on freezer alarming.
    that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
    Dec 03, 2008 | Kenmore Freezer 14.1 cu. ft. Upright...
    Freezer Temp Alarm
    Temp alarm come on, yet temp (fan blowing and cold air) working. Turn the temp control just a notch up and immediately the temp lite goes out. Later it will start up again. It seems the freezer is working fine, just the temp moritoring system is malfuncting.
    Sep 06, 2008 | Freezers
    GE upright freezer
    If this is a frost free model the fan could be bad. If not frost free it is probably low on freon. I don't recomment fixing this as you can never really trust the freezer again. Most of the time the leak can't be found and adding freon is only a temp solution.
    Jun 24, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
    Loud buzzing noise
    IF YOUR FREEZER HAS A TEMP ALARM, USUALLY LOCATED IN FRONT,BOTTOM, RIGHT CORNER, THE TEMP IS PROBABLY ABOVE THE SAFE TEMP FOR FREEZERS, (10 DEGREES) AND SO THE ALARM WILL SOUND.
    THERE SHOULD BE A SWITCH IN FRONT TO SHUT OFF THE ALARM UNTIL THE TEMP GETS BACK DOWN TO ZERO. THEN YOU CAN TURN THE ALARM BACK ON.
    IF YOU PLUG IN THE FREEZER AND TURN IT ON, IT SHOULD BE BACK DOWN TO NORMAL TEMP (IF IT IS EMPTY) IN ABOUT 24 HOURS. IF IT ISN'T, YOU HAVE OTHER PROBLEMS. CHECK TO BE SURE THE COMPRESSOR IS RUNNING.
    Apr 01, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
    Temp alarm going off
    What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
    Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
    GE 14.8 cu. ft. / 419 liter Chest Freezer FCM15DPWH Logo
    163 people viewed this question
    Top GE Freezers Experts
    Charles T Nevin
    Charles T Nevin
    christian nielsen
    John Tripp
    John Tripp
    Are you a GE Freezer Expert? Answer questions, earn points and help others
