Question about Maytag Dryers
Noisy dryer after cleaning lint
I tried to clean the bunches of lint that had accumulated underneath the lint trap in my Maytad Neptune dryer MDE3000AYW. What I couldn't **** out with a vacuumn attachment, I tried to get out with a fluffy duster. I'm wondering if I jammed some of the lint down into the workings of the dryer or dislodged something, because when I tried to use the dryer it makes a horrible noise and starts to smell.
  • 619 Answers
There is something caught up in the blower wheel. You will need to disassemble the dryer from the front to be able to get to the blower wheel housing to clear what ever you have jammed there and remove it. Everything is done through the front.
Posted on Jun 02, 2010
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
Tip
How to Fix Dryer Lint Problems
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Vacuum cleaner</span> </li> <li> <span>Screwdriver</span> </li> <li> <span>Electric leaf blower</span> </li></ul> <ol> <li> Remove the lint trap from the dryer and peel off the accumulated fuzz.<br /> </li> <li> Vacuum the top of the dryer, the floor nearby and underneath for lint at least once a week. When you remove the lint trap, tiny particles fly into the air and settle nearby. Behind and underneath the dryer are favorite hiding places for dryer lint.<br /> </li> <li> Disconnect the vent tube from the rear of the dryer and inspect it every month. Dryer lint accumulates more easily in flexible plastic tubes than rigid aluminum ones, because curves halt the lint's path.<br /> </li> <li> Clean the vent tube leading to the wall annually. As for the tube leading to the exterior, a trick that sometimes works is aiming an electric leaf blower down the tube. The leaf blower can expel the lint through the exhaust on the exterior. Before using the leaf blower, check that all duct work is fastened securely.<br /> </li> <li> Unscrew and remove the back panel on the dryer, if you're mechanically inclined. Particles that escaped the lint trap can accumulate inside the dryer cabinet, so vacuum this area.<br /> </li></ol>
on Jan 04, 2011 | Dryers
The dryer is taking hours to dry a load of towels. I cleaned the vent and it still is taking too long. Help?
disconnect the vent and feel the air flow out of the dryer, you may have to clean the inside of the dryer out, underneath the lint trap is a sensor that may have to be cleaned,also. Hope this helped Tim
May 21, 2011 | Maytag Neptune MDG5500AW Gas Dryer
The senser for Moisture only reads less go's through shuts down in about 5 min.
may have a clogged vent or dirty sensor, first disconnect vent tube run dry, if it works normal then clean vent tube, if not clean sensor which is located underneath lint trap. Good Luck Tim
Mar 06, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Dryer is working but will beep while running and continue to run. I clean lint trap after every load and have checked it.
underneath the lint trap there is a senor, you will need to clean all the lint out inside the dryer and the vent tube:
http://www.applianceaid.com/wpdryer_how-to.html
Nov 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Lint trap
http://www.pcappliancerepair.com/model-display.php This will show you how your dryer is put together. The lint has gone directly to the fan, where it could affect fan performance. You would have to remove the front off the dryer, and the cover off the fan area. It's not a bad idea to clean this area once in a while.
May 11, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag neptune dryer wont restart mde 3000 aya
Your dryer needs a new motor. It should cost about $200-250 including labor. Call a local repairman - not a national company. Give him the model number and ask him to bring the motor with him.
Mar 31, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
125 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
