Question about Toshiba Satellite A215-S7444 Notebook
Screen goes blank suddenly, gray, not black When I walk away and return it is often gray, have to reboot. Has done it while in sleep mode, while playing a game, while changing screens, not a real particular pattern. The 'can' light seems to be blinking off and on more and flickering more. Does not seem normal. Have run complete virus scans, regcure, and more. Been happening almost daily for about 2 weeks. At a loss for reason.
3 Suggested Answers
SOURCE: screen flickers and then turns gray
Access BIOS and test if the flickering continues.
If not, it is a Software problem, do a full system recovery
If yes, it is a hardware issue, better contact Toshiba tech support to have your LCD repaired if you are still in warranty.
If your not in warranty, you need to check out the LCD harness that might have been loosely connected.
Hope this helps...
Posted on Jul 25, 2008
  • 61 Answers
SOURCE: My Toshiba Satellite L305-S5877 will sometimes go
Go to "POWER OPTIONS" in the control panel.
You will see 4 options under "Power Schemes"
1. Turn Off Monitor.
2. Turn Off Hard Disks
3. System Stand By
4. Hibernate
Make sure that you select the option "Never", for all of them.... Hope that should work
Posted on Oct 02, 2009
Acer-E1-510. Why is screen blank and system reboots but nothing?
remove the battery and replace it and try again if that does not work it could be you boot files are damaged and you will need to do a system restore
Feb 20, 2016 | Computers & Internet
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
My display screen goes on and off
I find sleep mode nothing but trouble, eventually corrupts window files over extended use, go into power options, go to stand by and select never and click apply, next go to hibernate "top right" and click, make sure the check box is clear, if not! remove check and click apply and restart your laptop.
Apr 04, 2012 | Sony VAIO Computers & Internet
My Imac crashes. 10.6.4, 2 GB ram, 2 GHz core duo. I've started with a clean install and disabled (one by one) all start up apps. Out of the clear blue, the screen will go black & I have to turn it...
When you say "screen goes black," does the computer power down, or is it still operating? Does the sleep light come on? Does it respond to the keyboard and mouse? (Example: press the power button momentarily, wait a few seconds for the "Do you really want to shut down" message to appear, even though you can't see it, then hit the return key to answer "OK," and see if it shuts down.) Does the screen go black or come out of black if you tap the computer?
While your computer is working, go to System Preferences / Desktop & Screen Saver, the Screen Saver tab, click Hot Corners, and set a corner of your screen to Put Display to Sleep. Then next time your screen goes black, mouse your way into that corner, pause a few seconds, then mouse back out and see if your screen returns.
Jul 10, 2010 | Apple iMac 17" Desktop
After my Acer Aspire 5100 sleeps and the screen does not return
this is a problem with the standby feature there is a patch that Microsoft has put out that should fix the problem i think the main cause is having a usb device plugged in when going to sleep, search Microsoft knowldege base and it should pop right up
Jul 11, 2009 | Acer Aspire 5100 Notebook
Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Jun 25, 2009 | Computers & Internet
Macbook Pro goes from gray apple screen to black
Try booting into single user mode by pressing Command+S while booting. You should then be at a prompt. Type in:
fsck -f
and press Return. Let it run and see if it corrects any filesystem issues, then reboot when it's done.
Apr 25, 2009 | Apple MacBook Pro PC Notebook
Yesterday, I left my computer to talk with a
I would need some more information to completely help you. When you say you walk away and the pc shuts down and starts back up, does it close down (reboot) or does it go into screen saver / sleep mode? What button did you push for the power button light to blink? Have you put the PC into sleep / hibernation mode by pressing the power button once.
Apr 07, 2009 | Gateway MX3225 Notebook
Lap top screen goes blank all of a sudden
I assume that when you dont use your computer you put it in a sleep mode by pressing sleep button if this is the problem you are facing than there is nothing wrong with your video card and solution for this problem is that remove both the power cables and also remove the battery for time being, after some time put back your battery in the laptop and plug the power cable and restart your laptop it will work fine...........
Was this solution helpful.Show your appreciation by rating it.
Apr 08, 2008 | HP Compaq nc6320 Notebook
Toshiba Satellite A215-S7444 Notebook Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
