Question about Dishwashers
Fisher & Paykel Dishwasher
I have a single drawer Fisher & Paykel dishwasher model no. DS603-SS. It has been used approximately ten times. Now, when you turn it on you get an F2 error and the picture is a wrench. What do I do?
  • jana1029 Apr 09, 2008
    Thank you - your solution worked and saved me $80.00 service call. Many thanks.
    President:
  • 2,651 Answers
F2 refers to a motor error, you have the manual??? if not hereit is, try taking apart( its mean t for you to be able to service your self, its explained in the manual as to hoe to gfe down ther, the motor/ also called rotor is located within the drawer itself and under the silver screen every compponent twist out to reveal the next look for something under there somewhere preventin the rotor from spinning freely
http://www.fp.co.nz/admin/pdfs/pdf_usecares/527972D_DD_UserGuide_NZw.pdf
Posted on Apr 09, 2008
SOURCE:
Top half of my dish washer beeps when i push the power button
you will find this diagnostic service document useful.
http://applianceassistant.com/ServiceManuals/dishwasher-fisher-paykel-dish-drawer-dd603-ds603-service.pdf#zoom=100#scrollbar=1
The likely reason for top drawer not starting wash program when you press start button is the drawer home sensor is either faulty or the drawer is misaligned. This means controller thinks the drawer is open and does not start the cycle.
Apr 28, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Ds603 flood switch has been activated
The flood switch is at base of dishwasher housing under the drawer. Water leakage has occured to trigger this. Turn power off to dishwasher and take the power chord out. Pull the drawer out and use towels and hair dryer to dry the base. Put drawer back in and reconnect. Should work. Need to find the cause of leak. Either damaged lid seal or leaky hoses. Sometimes too much foam in detergent can cause it. Use recommended detergent and appropriate quantity per user manual.
Mar 14, 2014 | Fisher and Paykel 24 in. DS-603 Built-in...
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
Flood switch will not reset
The lid seal is damaged and it lets water go through and collect on the flood switch which may be triggering F1.
You will have to replace the lid seal. It is item 8 on page 14 of this diagram.
Jul 27, 2012 | Fisher and Paykel 24 in. DS-603 Built-in...
I have a Fisher and Paykel single drawer dishwasher. When each load is done, the dishwasher is empty of water, but in-between cycles, it slowly fills with clean water. I can stop this by turning off the...
I am assuming it is DS603 model.
You should check if the water pressure is not too high and put a reducer valve in the water tap.
More likely the inlet valve in dishwasher is faulty. Refer item 18 on page 13 of this parts manual.
You will have to check which of the 2 single valves apply to your model.
The part can be purchased from this site after confirming the part number from the manual above.
Please rate this soluiton if helpful otherwise post a comment
Mar 09, 2011 | Fisher and Paykel Dishwashers
Change Fuse on Fisher Paykel Dishdrawer
I have a single drawer F&P dishwasher. This morning a safety switch trigged. This afternoon when I went to use the dishwasher found that it had no power. There are no lights and there was a smell of something burning. The power outlet has power. Can you help?
Feb 08, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwashers Logo
330 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
