Question about Intex 2000 GPH Filter Pump and Chlorinator Combo
Need manual to connect the unit
Did not set up last year and want to make sure i'm doing it right?
  • 2,841 Answers
You can get a downloadable manual here. http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Posted on Jun 01, 2010
Why does my Swann have no display?
If you checked all cable connections and made sure you monitor is set to the right input and working properly, if the dvr has multiple outputs try them all first. If none of that works it maybe the the video card on your unit is bad and may need replaced. Swann dvrs typically only last a couple years because the are garbage.
Aug 28, 2014 | Swann Communications Home Security
Rinnai IB35ETR shows error 12 after room temperature reaches the set value, restarting it will show error code 11
Hi there, i have same unit and its got error 70 coming up. Which is faulty on off switch as per manual. I can confirm on off button on control panel, up on top is not working however remote is working. When i try to start it with remote it comes up but turns itself off with error 70 again. I tried to remove this control panel (pcb) from unit however it is still doing same. Now i am not sure if it is actually pcb panel which is faulty ? Please help ;)
Jul 15, 2014 | Rinnai Heating & Cooling
8 year old Air conditioner only used in the last 3 years more than a week or two a year. capacitor changed last year Unit was working a week ago now fan is not turning, Connector clicks when turn on...
Outdoor units require there own power supply, check the breaker panel and the fuses in the disconnect switch box next to the unit if there are fused, If the capacitor that was changed last year was not the right rating or configuration it may need to be corrected. One of the most common mistakes is to find a dual run capacitor with on side not functioning and jump in a capacitor for the non functioning side, if this was done it needs to be corrected with the proper capacitor or capacitors.
May 24, 2011 | Carrier 38CKC036 Air Conditioner
I want to register my GPS Nuvi 255 WT that I bought at Christmas time, I havent used the unit yet. I didnt get any updates yet. What do I need to do? Thank you
Right now your unit will work right out of the box. If you want to register the unit with Garmin, then there should be a card inside, or directions for online registration. As for updates, maps will be updated every year, with firmware updates periodically added. For the first 5 years of owning your gps, I wouldn't recommend paying the map update fee, as they often contain very little new information. They mainly encompass new developments, etc.Lastly, be sure to enjoy your Garmin, its one of the best car gps devices on the market.
Mar 03, 2011 | Garmin nuvi 255W GPS Receiver
No power, dead completly..does it have a fuse or anything that I can reset?
Not that I know of. Are you sure that the power cable you are using is the right one for the printer? Just because it fits the connection on the printer does not always mean its the right cord.
Check the power ratings on the back of the printer and compare them with the ones listed on the cord. Do they match? If so, does the cord fit the back of the printer snugly without wiggle room?
Have you tried other outlets to make sure there is no issue with the one your using now?
The power supply in HP printers usually lasts a lifetime. I doubt that this could be your problem.
When this has happened to me in the past, the problem has always been the power cord I was trying to use. Some power cords have fuses in them that can be bad. Is your cord a two piece with a box? Or a single piece cord? If its a single piece cord, I would question that it is the right one meant for the unit?
If its a two piece cord, make sure the voltage is right for the machine and follow the cord from end to end to make sure there are no other issues causing a power connection problem. Plug it into the printer and see if there is "play" when connected to make sure that it has not been stretched out and fits where it is supposed to go correctly.
If its the right cord and the connection is snug ect., and it still does not power on I would suspect that the power cord itself has gone bad for one reason or another. There was a type of cord that was issued with certain models of HP printers that was recalled due to malfunctions causing over heating a few years ago. I have not heard of any current issues, but you never know. Try replacing the cord and see if the unit powers up. If it does not then it will be a first and the issue your having is out of my expertise. (I am in my last year of school for my bachelors degree in Computer networking and have about 10 years experience in this field. This should help you gauge my advice)
Sep 27, 2010 | HP PhotoSmart 1115 InkJet Printer
I gave the xbox elite to my 17 year old son for christmas...we try to connect (we have fios) but we get an IP adress error....i've tried everything...he is trying to play call of duty 4.....is there a fee...
The service is called Xbox Live, it ranges in price from $7.99 for a month to $49.99 for 12 months in the United States.
But first you need to have the console connected to the internet.
Make sure you have a broadband connection (cable or dsl) not a dial-up.
Connect one end of the ethernet cord to the xbox and the other to the router or switch in your home network. You may have to enable the xbox in the router settings. Just find the IP address on the bottom of the router/switch for example 192.168.0.1. Now type that number into the internet browser on your computer (Internet explorer, firefox, chrome). Consult your manual for direction to set up a connection, also have the router set to DHCP.
If you set it up right you should be able to connect to xbox live. If not, try this website here, it might be able to get you connected.
As a last ditch effort you could try calling 1-8004MYXBOX but I doubt you will get help from there.
Any questions, just contact me at my profile or put a comment below.
I hope I helped you solve your xbox live problem
Jan 01, 2010 | Microsoft Xbox 360 Console
How do I fix this unit? HAVE HAD this unit since
ei, configuring router settings is kinda diffcult for new users, in order to use your router,, you need to configure your tcp/ip setting of your network connections, and you must know the statis ip addresss of your router and manually used it in tcp\ip.. and you need t ontain the subnet mas and dns server setttings as well,,
Dec 28, 2009 | Linksys WRT160N Wireless Router
Bose Life styles NTSC to PAL
First, using the remote Turn the unit off.
Then, using the remote Turn the unit on.
Next, Press the [System] button
Next, Press the [Right] Arrow (once)
Next, Press the [Down] Arrow (4 times)
Next, Press the [Up] Arrow (once)
Next, Press [Enter]
Last, Press the [System] button
Done
Apr 12, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Intex 2000 GPH Filter Pump and Chlorinator Combo Logo
82 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
