Question about NetGear DG834G Router
Not working with a different isp
Trying to use the netgear router i got with aol. changed isp to talk talk, but the modem is not very good. Want to try and use the old router, but cant get the laptop to see the modem.
    Sergeant:
    Champion:
  • 427 Answers
If the modem supplied by the isp isnt very good, call the isp and tell them the problem. They have to come and replace it for free.
Posted on Apr 19, 2008
SOURCE:
Netgear router installation
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Sep 12, 2010 | NetGear Computers & Internet
I use AOL as my ISP, with British Telecom supplying my telephone line rental. On Friday 2nd my internet connection kept dropping out, and then eventually stopped connecting altogether. My original router...
If BT tested the phone line is OK but did AOL test the connection to the Netgear router and get the IP address of your Netgear router.
The phone connection is OK but the ADSL connection from the telephone exchange may not be working, that is why you are not getting an ADSL light.
Jul 12, 2010 | NetGear DG834 Router
Can't keep on the network have a modem from comcast conneted to the netgear
Apr 16, 2010 | NetGear RangeMax Dual Band N Router Model...
I am trying to reinstall a netgear wgr614v9 router. when i hook it up to my modem the internet light stays yellow and i can't connect to the internet. i did change the DNS settings in the router a couple...
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
Click Here for more information about the routers and network
Mar 13, 2010 | NetGear WGR614 Wireless Router
Router not hooked up properly??
Mar 10, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
I have the same issue that everyone else is having
Dear,
This router is compatible with the modem UM175 but from the manufacturer Pantech for the ISP Verizon. The modem for this router is ISP specific modem and will not work with any other ISP.
This modem is incompatible with this router. Sorry!!!!
Check the list yourself:
http://www.netgear.com/Landing/en-us/3G_uSB_Modems
Hope, this helps
Aug 27, 2009 | NetGear MBR624GU Wireless Router
How can I set up Modem settings?
to get the modem configuration page It depends on the router which is used by your ISP . there are different types of routers used like NETGEAR, HUAWEI, CISCO etc
Most of the ISP uses NETGEAR , so to get the modem configuration page you need to type http://192.168.1.1, if it is not the NETGEAR router then you need to type http://192.168.0.1, there are big list for the different routers different ip is used.
When you forward the packets by entering http://192.168.1.1 if it is the correct one then your router will not forward those packets to others, the router itself will display you the configuration page i mean it doesnot forward those packets .
you can search the different routers and their list of the addresses to get the modem configuration page.
if you are using the USB modem or wireless connections those things which are discussed earlier doesnot apply because USB modem or wireless connection works on different mechanism, The single public ip address can shared to the large number of users and there may be large number of users working on the single public ip ...
Any further queries you can contact me
You can rate the solution
Regards
-Dileep
Jul 25, 2009 | HTC Verizon XV6700 Cellular Phone
I need to connect two modem/routers to the Internet for my LAN
install an aditional cable and network card to the second router
May 23, 2009 | NetGear DG834G Router
Router and Aol server not conected.
With AOL make sure you have set these values in the Netgear
ADSL settings as PPPOa
VC 0,38
MTU setting to 1400
If you still have problems
Start -> Control Panel -> Add/Remove Programs -> select AOL Connectivity
click Add/Remove -> use the repair option
Follow instructions to repair.
Once complete make sure modem is configured and switched on and
try restarting AOL.
It will search for your connection, find it and allow you to log on.
Configuratin instructions can be found here
http://www.howtofixanything.co.uk/howto-278.html
Feb 10, 2009 | NetGear DG834 Router
Been given 1 but its virgin but my isp is with talktalk, will it work?
Virgin is a cable provider. They give you a cable modem in to which you can plug the router using a network (RJ45) connection. This router is an ADSL modem router.
In other words, it could NOT have been used on Virgin, but it should work with Talk Talk as it is a standard ADSL connection.
Reset the Router back to factory default and enter your details.
Oct 24, 2008 | NetGear DG834G Router
NetGear DG834G Router Logo
43 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
