Hello, My 770 series Sansui CD Player does not read CD's. Just it takes the CD inside and does not make it turn. After 5 seconds it stops... Thanks already... Hakan AYDOGAN
    Problem Solver:
  • 14 Answers
The laser could be gone, or the digital circut that controls the laser is faulty, but more than likely the laser
Posted on May 31, 2010
  • BUDBOY225 Nov 16, 2013
    faulty laser needs replacing
Broken disc tray
Hello,i have a problem with my Philips CDR 770 CD. .. I purchased lately on the internet 10 CD digital audio VERBATIM,but will not read them ... only reads the Philips digital audio,writable and rewritable,the repurchase ... I hope you can solve my problem ... THANKS
Mar 22, 2014 | Philips CDR770 CD Recorder
Sansui DVD Vcr combo wont play Dvd's model no. VrdVD4005
you will need to run a cleaning disk in it , if that won't work then it will have to be taken apart to clean the laser eye manually
which then if you can't do this then you will need to take it to a local repair shop where they can do it
electech
Oct 26, 2008 | Sansui VRDVD4005 DVD Player/VCR
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
I have a Sansui Model VRDVD4000 and the DVD player keeps saying "load disc" even when the disc is in the player.
few small things to try. Turn off unit, unplug for 5 minutes, plug back in, turn unit on.
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Some DVD players simply will not read/play home made dvd's, or dvd copies.
Apr 28, 2010 | Sansui VRDVD4000 DVD Player/VCR
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
Nakamichi CD player ejects discs
I think either your disk player, or your CD is dirty.
You should probalyly try getting a Q-tip slightly dampened in rubbing alcohol .
and clean the inside of your player.
Or you should try a different disk
Dec 31, 2008 | Audio Players & Recorders
2004 camry cd player stopped playing
I have 2004 Camry. CD player did not work right after my 5 year warranty was expired. I heard from my friends that other Camrys have same problems.
It can not read the tracks in CD and ejecte, I told Toyota dealer, they said $250 to replace with new one including labor.
Any help would be appreciated.
Thanks,
Peter
Jun 04, 2008 | Car Audio & Video
Problem with transcend610 series
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Aug 16, 2007 | Transcend T.sonic 610 MP3 Player
100 people viewed this question
 Grubhead
Grubhead
