Printer is printing to fast and ink is faint on paper
    Scholar:
  • 162 Answers
I think you are working on draft or economy mode.
do the following:
- click start, select control panel
- select printers and faxes
- right click the printer model you are working on then select properties
- select printing preferences
- depending on the printer model, you can disable draft or economy mode by selecting standard mode or similar to this.
Posted on May 31, 2010
aicaxz
  • 511 Answers
SOURCE: faint printing after cartridge change & head cleaning
How about nozzle check output? Is it perfect? No missing lines? Do head cleaning, wait for 30 minutes. Check nozzle again. If there are no difference betwen two output, you may need cleaning head manually.
Posted on Sep 15, 2009
  • 25 Answers
SOURCE: Printer prints, but nothing appears on paper. Ink
if your printer is Canon, usually there are 2 possibility.
First one is the cartridge / head need replacement with a new one.
Second one is the main chip in the printer's board burned or damaged.
Posted on Sep 19, 2009
  • 86 Answers
SOURCE: the ink is full but it is printing faintly.
run the head cleaning utility
Posted on Oct 19, 2009
  • 21 Answers
SOURCE: HP Laser Jet P3005 Printer is printing very slow
It is usually dirty and old fuser. It would takes longer time to heat up and also triggering error messages. Try changing that.
Posted on May 09, 2010
ftw1952
  • 10319 Answers
SOURCE: when I print ther is no ink printing the paper printer window vis
click onto the Lexmark tab you have in your computer and run dianogstics on it to clean the print head. Now if any printer has ran out of ink and left not used for more than one day the head must be cleaned first with denatured alcohol
Posted on Jun 06, 2010
My printer is printing way to dark and using too much inc. can it be reduced
Yes it can. Toe save INC. you have to set the printer settings to FAST print. If you use special printing commands such as Poster, Premium, BEST, Photo paper, or as such, you put the demand on ink at the highest ratio. If you set the command to plain paper, fast printing, standard paper type, etc. then the printing heads use less ink or INC.
Feb 09, 2018 | PRINTER Office Equipment & Supplies
Km 1620 double side copy makes one side clear and the other side faint
Clean print heads remove ink cartridge and take a paper towel wet it and clean the cartridge off of there is dry ink on it. Your ink cartridge could be almost empty. Ink cartridges dry out fast. If you do not use ur printer often the ink drys out.
Oct 01, 2016 | Office Equipment & Supplies
My HP 3550 deskjet will simply not print. It goes through the motions and seems to be printing --but the page is blank or very faint. I have already cleaned and re-calibrated the printer
Check ink-levels -- no ink means no printing.
Run a few more "print-head-cleaning" cycles -- clogged ink-jets cannot spray ink onto the paper.
Jun 20, 2011 | HP DeskJet 3550 InkJet Printer
Printer is only half printing doc on each line, have done test page, very faint, aligned ink, clean cartridges, all with top v faint and bottom dark ink, new cartridge last fri and was working well,...
Open the rear of the printer and make sure theres no paper jam or broken parts.
Try printing a document with the rear of the printer open and watch to see if anything out of the ordinary happens.
Mar 01, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
My ink levels are fine but print is very faint and lines are missing, it is illegible
Your print head is clogged or damaged. Press the print head into a paper towel. You should get a nice block of black or three stripes of color. If not, try placing print head on paper towels soaked with warm water to get the ink flowing (ink may soak through paper towels, so beware of where you do this). Then try pressing the print head onto dry paper towels as before. If you can't get the ink flowing, you need a new cartridge because the print head is clogged with dried up ink.
Dec 19, 2009 | Lexmark Office Equipment & Supplies
PUT IN NEW INK CARTRIDGES BUT COPIES STILL BLANK AND PRINTING EVEN CHANGING ALL SETTINGS
how did the paper exit inot your pritner? Its act like printing or its fast and smooth? If its act like printing you just need to clean the printhead or if cleaning printhead did not solve the issue you need a printhead replacement, Now if the paper exit in your printer fast and smooth you need to replace the printer and the printhead., You need to call kodak for support toll free 1 800 421 6699 ext 05., The troubleshooting may apply also for blank documents using word or any other application.,
Nov 16, 2009 | Kodak ESP 5 Printer
Hp photosmart 7760 the prints will not dry
hi
goto the cntrol panel--->printers and faxes--->right click the printer icon
click on the printing preferences and check the print quality ,try to set it to fast draft...this should save the ink as well as dry it faster.
hope this works
Jul 14, 2009 | Office Equipment & Supplies
Printing is very faint. How to change or add ink printer device.
This is most likely a ribbon impact system. Any office supply store should have the ribbon you need, with information on compaitability on the package.
Remove the paper roll and gently but firmly pry on the bezel surrounding the paper exit path. Examine the sides of the ribbon casing for any clips or fasteners.
May 22, 2009 | Victor 1280-5 Calculator
Black ink is faint
First I would suggest performing any head alignment functions with your printer's menu to be sure you have the stepper motor feed adjusted properly. Use the paper you are currently printing on for this procedure so that the thickness of that paper is factored in.
If you stil see the banding after doing this, you can use the Advanced Media Control button under Printer Settings in ColorBurst to fine-tune the paper feed adjustment. Print out the "Media Advance.tif" target (located in the ColorBurst/images & Targets folder) to use as a guide. For white bands, you'll need to enter a negative number (to shorten the paper feed).
Dec 12, 2008 | Xerox Phaser 6110 All-In-One Laser...
101 people viewed this question
k24674
jasbo
jasbo
