Question about Rotary RotoZip XB-LF5 Laminate Flooring X Bit
I have had new laminate flooring installed and taken old skirting boards off to be replaced.There are gaps around the doors that need to be filled.What do you suggest?
    Novelist:
  • 145 Answers
Well it depends on the situation, and I'm not sure of the situation by what you told me. If the gaps are in the laminate floor I would use wider molding to cover to the gaps. I have also found silicone caulking to work well in situations where there are gaps as it remains pliable and last a long time without cracking. Make sure if your going to use it you buy 100% silicone, and I have found GE brand silicone caulk to work the best in all situations.
Posted on May 31, 2010
NOt t all happy with my 1year old style selections laminate floor. It creaks with every step. Has hooked up
contact the floor layer who did the job and check on the work and material warranty
Sep 16, 2017 | Building Materials
Motorcycle is losing compression and noisy
if it is a water cooled engine the ring gap at the bottom of the cylinder should be around .010"
rings have to be installed the correct way up or the compression doesn't help push the rings against the cylinder walls for effective seal
piston skirts will touch the cylinder walls as the pressure pushes the piston to one side as it pushes the piston back down the cylinder
I have to ask did you put an old piston back in the new cylinder
was the new cylinder standard size or over size
what was the ring gap before you fitted them to the piston
did you use new rings or the old ones --maximum rin gap is .025"
rings don't wear in , just wear out
why did you replace the cylinder in the first place
was it because of low compression or taper wear
as silly as all this seams it is all very relevant to your question
Mar 11, 2016 | 2011 kawasaki KLX 250
How to remove baseboards?
Get yourself a good hammer and crowbar-type of chisel, and follow the instructions in this video by David White of Flawless Flooring:
How to remove skirting Tutorial
May 26, 2014 | Dream Home - St. James 12mm Horizontal...
Laminate flooring repair
If it's older laminate it will be glued together making repairs impossible.
Apr 06, 2013 | Vacuums
What are the advantages of laminate flooring over hardwood flooring?
First, you can get the exact visual design that you wanted and it will cost you considerably less. Second, laminate flooring can be installed above and below the grade unlike hardwood flooring. Moreover, the laminate flooring is installed without using any nails or glue which make it much easier to it yourself. Furthermore, laminate flooring is extremely durable, easy to maintain and can be replaced easily.
Feb 06, 2013 | Building Materials
Can I put laminated floor over my carpet?
Laminated floors are possible to install over virtually any type of floor you have although over carpets and especially high-pile carpets it is not advised.
For how long do I need to wait after I installed my laminated floor?
Glue-less laminated floors can be installed fast and are able to be used immediately. Glue laminated floors need to set for 18 to 34 hours before being walked on.
How much laminated floor should I get?
You get an idea on how much laminated floor you will need by measuring the length and the width of the rooms that you plan on installing laminated floor, multiply the length by the width and add 10 percent for installing errors and variation in floor design.
I rented a bostitch MIIIFN to install bamboo hardwood flooring. The nailer is splitting the tongue of the wood. Is there some type of adjustment that I can do to stop the splitting?
you do not use nails to install bamboo floor! EVER!
bamboo flooring is installed on glue alone, and then some weight is put on the top to keep it down while glue is binding. this usually takes about 12 to 24h, depending on climate, temperature and humidity.
if these are standard board, they are 6' long and between 4" and 6" wide, depending on manufacturer. all ends indexed (tongue and grove) and pre-finished.
bamboo is a grass, but because of glue used in it's construction (formaldehyde) it makes it very hard, even harder than ironbark, in jenkins scale, bamboo floorboards are between 13 and 15 (pine is about 4.5, oak about 10 in this same scale)
bamboo expand as well with humidity, and you need to leave 10mm free space along the walls to allow for that expansion. this space is normally convered by skirting. skirting is usually about 19mm thick, therefore gap between 10mm and 15mm is ok.
if running board is longer than 13m, you need to leave expansion joint on it as well.
if you are installing directly on the concrete, do not forget about moisture barrier, if this is on already existing wood floor or cork, moisture barrier is not necessary, but you need to remove old paint from subfloor (sand it to "bare" wood) to allow better glue adhesion.
if you are installing bamboo over the bearers, then use some sort of subfloor and glue bamboo on the top of it. you cannot just stick bamboo to the bearers, bamboo is too thin (15mm) for that
NEVER NAIL BAMBOO FLOOR!
you use glue and sparringly pin-nails on bamboo skirtboard (even pin-nail tend to explode them...).
i hope that this short explanation will help you, it will be better actually if you ask some professional floor shop in your area how to do that...
if you are happy with my advice, please do not hesitate to leave your comments or vote (or both...) for me, thanx!
Aug 03, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
Rotary RotoZip XB-LF5 Laminate Flooring X Bit  Logo
96 people viewed this question
Top Rotary Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
raysaw
Are you a Rotary Tool and Hardware - Other Expert? Answer questions, earn points and help others
