Question about Kenmore 17829 Free-standing Dishwasher
My dishwasher will not drain and is not hooked up to a garbage disposal
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 23, 2010
Dishwasher not draining completely after new garbage disposal installed
If you hooked up the drain to the disposal directly there is no vent in the line. Use the air vent on the sink to connect the dishwasher drain hose. If there is no air vent, then you'll have to install one in the sink.
Jan 26, 2014 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My dishwasher isn't draining. The garbage disposal is hooked up separately.
Is sink drain line clogged?
Disconnect drain line at sink tailpiece and lower down to see if water inside dishwasher drains.
Call serviceman to clear clog in dishwasher hose, or repair dishwasher pump motor.
Oct 13, 2012 | Whirlpool Gold Dishwasher with Quiet...
Dishwasher hose is hooked up separtely from garbage disposal but still dishwasher not draining
Hi - Is the unit making a grinding noise? If so, contact a professional because you may possibly have a defective drain motor/pump.
Oct 13, 2012 | Frigidaire 24 in. PLD2850 Built-in...
Hi, I just purchased a whitewesting dishwasher for my condo and it has a problem with draining. I just got rid of my old dishwasher for the same problem. What do you suppose is wrong? the water just...
It sounds like you are haveing a problem with the main drain line that the dishwasher hooks into.... If both dishwasher are not draining right. Does it drain into the side of the Garbage Disposal????
Make sure that the Garbage Disposal is clean and drains OK before you start a load of dishes.
Jan 31, 2011 | Dishwashers
Dishwasher will not drain totally after it has finished the cycle. I recently had a new garbage disposal installe and every since then the dishwasher will not drain. Is it something to maybe do with the...
disposal has a plug in it where the drain line from d/w hooks up remove drain line from disposer and stick a screwdriver in hole to remove plug remove plug from inside disposer with a pair of needle nose pliers that should take of it
Oct 26, 2009 | Dishwashers
Can i connect my Hoover HD73M Dishwasher to a cold feed?
First off, you need a hot water feed line for your dishwasher, not cold water
Secondly, if you have a garbage disposal installed on your sink you can connect the dishwasher drain hose to the side port on the garbage disposal. That's what that little port is for anyway. If you do have a garbage disposal and hook the dishwasher hose to it then make sure you take a hammer and screw driver and knock out the little plastic plug that's inside the garbage disposal port before hooking up the hose to it, if you don't you'll flood your kitchen.
If you don't have a garbage disposal on your sink, then you're going to have to replace a piece of your sink's drain piping with a wye (Y) tailpiece. The tailpiece has a small branch that comes off it to where you can connect the dishwasher drain hose.
Regardless of which way you hook up the drainage and water lines, make sure you test out the work you did by running the dishwasher and keeping an eye on it. I can't tell you the number of times i've seen people hook up stuff like this and not test it and then when they go to use the dishwasher it floods the kitchen..... usually when people are sleeping at night. Test your work.
Aug 01, 2009 | Hoover 24 in. HD73M Free-standing...
My quiet partner 4 will no longer drain, I recently replaced my garbage disposal & the problem began after that.
There is a plug you have to remove on the garbage disposal where you hook up the washer drain hose.
Check the instructions with the disposal.
You'll have to deinstall the garbage disposal, remove this plug and reinstall.
May 05, 2009 | Dishwashers
Water draining backinto dishwasher from garbage disposal
You have a clog where the drain pipe leaves the garbage disposal that isn't draining fast enough or not at all. Or it could be a clog in the dishwasher drain hose where it connects onto the disposal.
Apr 07, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Water will does not drain completly the hose is not kinked nor is this unit hooked up to a disposal. maytag portable unit
  • Check sink drain and drain hose for restrictions
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Aug 26, 2008 | Maytag Dishwashers
Dish washer
The drain in to the garbage diposal is clogged.  Remove the drain hose from the dishwasher and clean the hose.  Also check the inlet to the garbage disposer and clena it.
Oct 28, 2007 | Dishwashers
Kenmore 17829 Free-standing Dishwasher Logo
64 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
