Question about Panasonic DMR-EZ47V DVD Recorder/VCR
VCR, DVD PLAYER
I HAVE A VCR, DVD PLAYER COMBO. DVD PLAYER DO NOT OPEN TO INSERT THE DISC, A COMMAND "SAFE" IS DISPLAYED WHEN I PRESS THE OPEN/CLOSE SWITCH. PLEASE HELP ME TO FIX THIS.
  • Anonymous Mar 22, 2014
    Hi I have a 19inch whalfdale tv / dvd combo, it will switch from the tv to the dvd player for apparent reason.
I was unable to eject my dvd from a Panasonic VCR/DVD PV-D4742 model. The deck kept showing Safe.
I contacted Panasonic. The last suggestion given was to unplug overnight. I did this, and I was able to successfully eject the disk. Thought might help someone. I was aabout ready to take it to a repair service.
Posted on Jan 06, 2012
Try resetting the unit. Push and hold the on/off button for 10+ seconds. --or-- Look for a reset button behind the drop down door, and gently depress it with a pen point for a couple of seconds. If this does not work, try calling Panasonic.
Posted on Apr 16, 2008
Stuck in safe mode
To begin with someone needs to open and look inside the unit to see if the disc is out of position or jammed, this could trigger the safe mode.
Dec 13, 2012 | Samsung DVD-V9650 Dvd / Vcr Combo Player...
Necesito intruciones del este urc-3021bg1 para programar el televisor vizio.
From the Manual:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR, CBL/SAT,or TV). NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3 . Press and hold SET until the LED (red light) blinks twice, then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
For VIZIO TV try one of the following codes: 1758; 0178; 10178; 627; 502
Mar 04, 2011 | One For All URC-3021 Remote Control
I have a surround sound Zenith model # ZHX313 (vcr,dvd and turner). I turned on the progressive scanner while in menu but now I can't turn it off. I've tried unplugging and also tried holding down the stop...
It's unlikely that you've broken it - you appear to be using the wrong method for switching it off.
Correct instructions for turning Progressive (P) Scan off:
1. Remove any disc from the unit and close the disc tray.
2. Wait for the "NO DISC" message to appear on the display
3. Press and hold the "STOP" button on the front of the unit for at least 5 seconds then release.
The video output should return to the normal setting and "P/SCAN" should disappear from the display on the front of the player.
If you are still unable to switch P/SCAN off, please post back for further assistance.
Regards,
BElectric
Jan 03, 2011 | Zenith ZDX-313 DVD Player / VCR Combo
I have URC3220 remote and a Magnavox TV How do I program it?
PLease follow the steps below
1.Turn on a desired device (e.g.,VCR or DVD player) and, if
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter
6.You are set
thanx
Jul 24, 2010 | One For All URC4110 Remote Control
HOW TO EJECT DVD THAT THE PLAYER WILL NOT READ
turn the unit on, set to dvd and turn off. then press the dvd open/close button, it should turn on and open without reading the disc.
Mar 22, 2010 | GoVideo Go Video DVD/VCR Combo
Wont play dvd's.
If this happens when you insert a DVD disc then most likely the laser assembly is failing in the DVD drive. In most cases it will probably still play CD's. The part number needed is LSVQ0087 and isn't cheap as seen on the following ebay posting. Please take a moment to rate my answer. Thanks.
http://cgi.ebay.com/Panasonic-LSVQ0087-BLOCK_W0QQitemZ390013781267QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5acea20513
May 10, 2009 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
I would like an unlock code for two vcr/dvd combos. Can you help?
If you need a region free code, here it is:
Make sure you have no disc or tape in
Turn it on.
When the display shows "no disc"…...
1. Press the DVD button on the REMOTE CONTROL so the Samsung DigitALL logo appears on the screen
2. Press the SUBTITLE button on the REMOTE CONTROL
3. Using the REMOTE CONTROL enter the code: 7, 6, 8, 8, 4
4. The current region should be displayed on the screen. (eg "04") If this doesn't happen then turn off
and then on and try again
5. Press the 9 button on REMOTE CONTROL for Region free or new region number
6. Press the Open button on PLAYER
7. Press the Close Tray button on PLAYER.
8. Power the unit off, then power the unit on again
Nov 25, 2008 | Samsung DVD-V4800 DVD Player / VCR Combo
DVD player cannot read DVD disc.
Have you tried other DVD's in this unit and they work? If so it might be just an incompatibility issue with that DVD in your TV.
Nov 16, 2008 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
239 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
