Question about Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor
Trolling motor maxima 101 is hooked up to 3 batteries = 36 volts ; appears that it is pulling off of one battery only ; all 3 batteries are fully charged
3 Suggested Answers
  • 4 Answers
SOURCE: diagram of 36 volt hookup for trolling motor
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
budman772357@embarqmail.com
Posted on Nov 12, 2009
bigcass
  • 35 Answers
SOURCE: is a minn kota mag 36 just 12V or 12V -24V run
I believe the Mag 36 is a 12v and the Mag 40 is a 24v......Ive been doin a little research and cant find anything that points to a 12 and 24v system.....
Posted on Jan 19, 2010
Hooking up a 36 volt charger to three 12 volt batteries in series
first of all do you have 3 or 4 batteries your cranking battery is not to be wired into this 36 volt if you have 4 batteries you have 3 for trolling motor and 1 cranking battery look on your charger see if the banks or numbered 1 2 3 4 .... you got to find what battery is # 1 depends on how they hooked in series if you hook charger on wrong battery most the time a red light comes on telling you wrong battery move wires till green lights come on all batteries.# 4 goes to cranking battery if you only have 3 batteries you don't have 36 volts you have 24 volts and a cranking battery if so # 3 goes to cranking battery
Aug 29, 2013 | Minn Kota Boating
I have a motor guide great white saltwater series 109 lb thrust 36 v trolling motor. I hooked the 3 batteries up right but it isn't running right, it's very slow. What do I do with the grey wire which has...
running to slow indicates voltage too low
you will have 3 X 12 volt batteries connected in series ( positive to negative to positive to negative with positive to motor The first battery negative connected to the ground on the motor
the multicore wire cable is for 12 volt draws as in fish finder, light etc and can be connected across any single battery terminals
They could also be for a foot controlled pedal that is forward and reverse operation
that will be explained in the user manual
Dec 06, 2017 | Car Audio & Video
I don't have any slow trolling speeds. Only fast speeds on my Pro Series 6700 trolling motor. Any ideas? Also, it is a 24 volt system. How do I properly hook up the batteries. The two batteries are...
To hook up to 24 volts you need to join a positive cable from one battery to the source[motor or controller] and the the negative cable goes to the positive of the next of the next battery,then the negative [of battery #2] goes to ground,same for all 24 volt systems.If the slower speeds don't work then the rheostat in the accelerator handle could be at fault,but getting the 24 volts sorted out may fix everything.
Jul 22, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
How do i hook up the 3 12 volt batteries for 36 volts
Not sure why you need 36V but here's how.
<--P---N----P----N----P----N------>
Bat 1 Bat 2 Bat 3
You basically string them together. If you put a voltmeter on each end of the group you should have 36 volts or near it depending on the charge of the batteries.
Mar 13, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
How to attach leads to batteries
This is what they call a series connection. The two 12 volt batterys are wired together in a series to make one 24 volt battery. The positive wire or red from your trolling motor goes to the positive post on battery 1. The negative lead from trolling motor goes to the negative post on battery 2 then there is a short wire that goes from negative on battery one to positive on battery 2. NOW GET THAT HOOKED UP AND GET IN THE BASS.
Nov 29, 2009 | Electrical Supplies
How do you hook up the 2 batteries to a 24 volt motorguide trollong motor
To get 24 volts from two batteries they are wired in series. A wire is connected from the "+" terminal of the first battery to the "-" terminal of the second battery. Your trolling motor is connect to the "-" terminal of the first battery and the "+" terminal of the second battery. You will be operating at 24 volts.
Jul 12, 2009 | MotorGuide Electrical Supplies
Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
Mar 01, 2009 | Minn Kota Boating
Wring for trolling motor
just hook the two batteries up in series. To do this buy one short cable and use it to hook the positive of one of the batteries to the negative pole of the other. Then use the two remaining poles, one positive and one negative to hook up to the motor. good luck
Jan 18, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Logo
47 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
