Canon iP8500. Black ink ran out. Replaced cartridge and not printing black. Replaced cartidge with another new cartridge with same result. All other colours ok. Have done deep cleaning several times without result. Any suggestions please? Bryan
  • Bryluk Apr 08, 2008
    Using third party cartridges
  • Bryluk Apr 09, 2008
    Many thanks - put me in the Right direction.
  • 2,337 Answers
Download setup guide, follow it step by step to fix your printer.
Posted on Apr 08, 2008
    Genius:
  • 3,422 Answers
HI,
First try to soak the ink pin onto the lukewarm water for 30 seconds and wipe it out until dry and then insert it back to the ink holder.
More than likely you have a problem with your printhead not your cartridge but no genuine cartridges cause the most problems. It either dries out, clogs up or a piece of jammed paper gets stuck on the printhead.
Run the cleaning cycle a few times to try to resolve or open the scanner cover and try to see paper under the carriage/printhead on the right hand side just under the cover.
Otherwise the printhead requires replacement.
Goodluck,
Please don't forget to rate the solution.
  • Priya darshan Apr 08, 2008
    See that's what i told before.Please immediately switch to the genuine ones.
    Please do not forget to rate the solution no.2
    Scholar:
  • 133 Answers
You dont have to clean your cartridge again and again
and specially if its new
the problem is with your print head
try to find out your black print head which is lockated below your black cartridge and safely clean it with some tisue or soft paper
but please do thi gentely
because if your printer head is get demaged you must have to replace it or may be whole printer
  • Anonymous Apr 08, 2008
    then first try to using original cartridge
    Genius:
  • 1,142 Answers
Are you using original cartridge
    Best option for you is to click on this link and follow the procedure to find where the issue lies.
    http://www.usa.canon.com/consumer/contro...
    Please dont forget to rate Fixya
SOURCE:
Canon pixma iP8500 won't print, blank pages
The colour cartridge is badly clog. put tissue with warm/hot water below the head, wait for about 30 minutes. If tissue is coloured, the dried ink inside head is out. Is it not, do suction from the outlet pipe of head cleaning mechanics.
May 27, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
Compatibility of Ink cartidge.
The MP600 does not use the 40 or 41 cartridges, it uses individual color (and black) ink tanks. But other models (MP190, MP460, MP470, etc) do use these cartridges. The error message you are receiving indicates that the printer does not recognize the cartridge you installed as a valid black ink cartridge. This can mean that either the cartridge is faulty, or that the printer has a problem.
I would suggest trying another new cartridge, and if you still get the same error, to contact Canon for support options if the unit is still in warranty.
Oct 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Mfc-240c reading offline and empty black
Regarding your problem: If one of the color ink cartidges is out of ink, the MFC 240C printer will not operate when you only install a black ink cartidge. It requires that all four catridges have ink available in them for it to function. When you examine a cartridge it may appear that it has a little ink in it when you get message that the cartridges needs to be replaced because a little ink remains to prevent the print head from drying out. [email protected]
Sep 24, 2008 | Brother Multi-Function Center MFC-240C...
Black ink not recognized
Select printer, properties.
Select printing preferences, select advanced.
Select more options.
Make sure you do NOT have Use color cartridge for all black printing selected.
(I had set that a while ago when my black cartidge ran out when the kids had a paper due - I forgot I had reset it. Once my color cartidge ran low, everything printed pink).
Let me know if that works for you.
Jun 05, 2008 | Dell 924 All-in-One InkJet Printer
Bought today a hP7200 All-inOne Series. Set up and received the following: Error message "Incorrect Ink Cartridge: The following ink cartridges cannot be used after device initializaed and must be...
hi friend
try remove your printer cardige & rinstall it if u have not remove your printer cardige nosel raper so remove tape of the nosel try to install & print
Apr 13, 2008 | Office Equipment & Supplies
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Open Questions:
jasbo
jasbo
Ekse
Marvin
Marvin
