Question about Whirlpool SF367 Gas Kitchen Range
Igniter keeps clicking
Not in use the range keeps clicking like you are trying to light a eye or the oven
Looking same proable did fix it and what ddid you do
Posted on Jul 23, 2010
Belling FarmhouseCookcenter 111 - oven keeps going on and off, and igination keeps clicking
Your hoses may have to be replace in order for the gas to get to the stove right.
Jan 02, 2013 | Kitchen Ranges
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Wirlpool gs475lems Oven will fail to light and keep temp.
I HAVE A 2 MONTH OLD GAS RANGE AND IT APPEARS ED-F3 AND THE OVEN DOOR IS LOCKED HOW DO I GET IT TO UNLOCK
Feb 15, 2009 | Whirlpool GS475LEKS Gas Kitchen Range
HELLO MR BEAN
These problems are difficult to diagnose sometimes without being there to actually see what is going on. Now...let me see if I can remember all of this. You replaced the spark module and have a spark at each burner now. You also checked for gas leaks and didn't find any. Now, you're telling me that the oven isn't working? Most oven igniters I'm familiar with are the glow bar type. Which means they don't spark at all. They glow to a certain current potential (roughly 2.7 to 3.3 amps) before the gas valve is opened and begins to flow. Once gas flow is achieved, the igniter ignites the gas. Now, when these igniters get old, they become weak and will not provide enough current to open the gas valve, or, they take a long time to ignite. If this is your case, then you need to replace the oven igniter. Does this help you? PS Keep in mind, some ovens have two separate igniters. One for the broiler and one for bake. Does the broil function work? If so, the oven switch is good.
Aug 07, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven in DCS gas range doew not turn on
Well some of the older ones have a unit that is sorta like a pilot light which keeps you safe by not letting out gas before it ignites so as to not blow up. This macanism is probably bad. I use to replace them on Tappan ovens. They would last a couple of years and then would go out and to replace them then was about $80.00. Easy to do. They are usualy located inside the oven somewhere and look like a glass eye on one end with a small 1/4 inch gas line connecting to the other end.
Jul 30, 2007 | DCS RGS-486GD Gas Kitchen Range
Whirlpool SF367 Gas Kitchen Range Logo
103 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
