Question about Kenmore 23822 Top Load Washer
Washer was woking fine. Put a new load going, it
Washer was woking fine. Put a new load going, it filled with water and stopped. Will not work at all and is full of water
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Jun 01, 2010
Lg top load washer keeps filling and has to be manually stopped but it will drain when put on the spin cycle.
HI,
From your description, it sounds like there may be a problem with the inlet water solenoid valve(s). They can stick after several years of use. The se valves are located in the machine, just inside where you connect the water hoses.
Jul 25, 2015 | LG Washing Machines
My Frigidaire GLWS1339CS1 fills but stops about 2 inches from the top? It has done this since I bought it and otherwise works fine. A tech came out and told me to fix it would cost more than buying a new...
The washer will not fill all the wayto the top.yourmachine is functioning properly.when you have an empty tub and put it on super load and fill it up there should be 12 to 14 inches of water in the tub. that is the normal operating settings for your washer.
Oct 03, 2011 | Frigidaire GLWS1349A Top Load Washer
Won't stop filling with water, seems to fill to top and keep filling
there is a water connector that the water lines from the house connect to the washer. you will need to take the panel off. you should see a blue plastic box where the hoses connect. you will need to replace this piece. it should have wires on it and that tells the washer when to open the valve for water to come through and when to stop.
Jan 27, 2011 | Frigidaire FWS833A Top Load Washer
Water level dont stop I bougth a new part and still have the same problem the water dont stop.
put the washer on cold,start to fill washer, turn washer off if water still keeps filling you have a bad water valve,do the same test on hot,if both turn off when you push stop then check the water level hose from the water level switch to the tub,if both ends are secure then replace the water level switch-mike
Feb 18, 2010 | Kenmore 22422 Top Load Washer
Water over fills and machine does not start washing
put the washer on warn and start to fill,turn washer off,if it keeps filling then you need a new water valve,if it does not stop filling your water level,hose has come loose or the water level switch is bad-mike
Feb 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Water Overflow
hi there,
i would recommend checking the water level switch or lid switch and also the cable leading to it. that is what sends a signal to the machine control to stop filling with water.
Oct 10, 2008 | Whirlpool LSR7333 Top Load Washer
Kenmore 23822 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
