Question about Frigidaire Ovens
Receiving and F9 code with beeping. - Frigidaire Ovens
  • Steve Kugler
    Steve Kugler May 31, 2010
    Thanks I realigned the latch and all is now well.
    President:
  • 949 Answers
An F9 code is an indication of a door latch failure. I would need the exact model number of your oven to get you the right part numbers you might need.
Typically this is due to a switch or solenoid on the latch assembly just above the oven door in the center. It can stick after a self clean cycle, it can get contaminated with dust and dirt and fail, it can fail if the door is not closing all the way and heat is escaping from the oven while in use.
Let me know if you have questions.
Posted on May 31, 2010
F9 still appears after unplunging and replug
Hi Don, this is Z. Thank you for your post!
If you are receiving error code F9, it typically indicates that the maximum oven door unlock time has exceeded. If resetting the power did not clear the error code, it would be advisable to contact an experienced appliance repair tech to assist further since your range may possibly have a communication error with the EOC (Electronic Oven Control), lock motor assembly, door light switch or door latch assembly. Hope this helps!
Jul 19, 2014 | Frigidaire Ovens
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
F9 is appearing in the clock window
HI. This will code is indicating that the oven door lock mechanism is experiencing difficulties. Check the wiring to door lock switch (the wire harness may be connected wrong, or loose). Check for stuck lock switch, as well.If the wiring is not loose, or connected improperly, this will lead to a failed door lock mech. it will require you, ro your service tech to replace it, in this case.
F-9 Oven door lock failure
Dec 07, 2009 | Whirlpool Ovens
Hi, my GE Profile Mod# JBP90GV2BB S/N ZM223214G began beeping this morning and posted an F9 code in the display. The stove hasn't been used in 2 days. What does the F9 code indicate and what ccan I do to...
F9-- Failed Lock switch detected.
Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
If the wires are ok and, the switch is not stuck, replace it asap.
Jul 10, 2009 | GE Profile JTP18 Electric Single Oven
My self cleaning oven door will not open, and keeps beeping and
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$%^@#
Apr 19, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self clean results in f9 and beeping
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
utut
Apr 07, 2009 | Frigidaire FEB27S5A Electric Single Oven
Stove door locked and continues to beep and flash code F9
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$%^^%$
Mar 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door lock lites keeps flashing but the door is not locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Ovens Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
