Question about Panasonic Microwave Ovens
Microwave runs for 3 seconds and stops
My inverter panasonic microwave runs for 3 seconds and stops
  • Panasonic Master
  • 9,085 Answers
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on May 31, 2010
2 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: Mi panasonic prestige inverter microwave will not
If so, see http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt http://031d26d.namesecurehost.com/mwd/doorsw.txt
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Posted on Nov 23, 2011
Panasonic microwave problem help needed
Dan, That unit has an inverter, that is the power source for the part that puts out the Microwave energy called the Magnetron. The inverters are expensive and I stopped doing warranty work for Panasonic beacuse of them. Some pencil pusher somewhere though it was a great idea to replace 3 common fairly inexpensive parts. with that dang inverter. Microwaves have come down a lot in cost, I would buy a new one without an inverter. Sorry, wish I had better suggestions, I DO NOT LIKE THEM. LOL Sorry! Panasonic and their distributors are always out of them and there so expensive no one wants to stock them. I have had new ones sent to me that were already bad.
Aug 20, 2017 | Microwave Ovens
My panasonic microwave NN-S954WF will run a few seconds and then stop. What should I check?
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 2-3 seconds, see if this describes what's happening:
Nov 16, 2011 | Panasonic NN-S954WF Microwave Oven
Jul 18, 2010 | Panasonic NN-P295SF Microwave Oven
Panasonic NN-S254BF microwave oven runs for 2-3 seconds and then shuts off'
May 31, 2010 | Panasonic NN-S254BF Microwave Oven
Time set does not complete
You didn't mention your brand or model number, but I'll assume it's a Panasonic since you posted this under a Panasonic category.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
May 26, 2010 | Panasonic NN-T994SF Microwave Oven
Power to microwave but does not cook food
May 26, 2010 | Panasonic NN-H264 Microwave Oven
The oven stops partway into the set time, and doesn't heat.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other. Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these. You can find an authorized Panasonic servicer here. In Canada, you can find an authorized Panasonic servicer here. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Jun 11, 2009 | Panasonic Microwave Ovens
Panasonic microwave shuts off
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Dec 25, 2008 | Microwave Ovens
Shuts off but everything else works
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
Nov 08, 2008 | Panasonic NN-S542 Microwave Oven
It stoped
Nov 01, 2008 | Panasonic NN-S542 Microwave Oven
Microwave Ovens Logo
892 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
