Question about Singer 2639
The bobbin case keeps sliding and popping out in the middle of sewing something. I'm having to unscrew the bobbin cover plate and put it back in on an average of four times each time I sew.
  • 40 Answers
This is a real bummer! check to be sure you have inserted the bobbin case fully and correctly. Make sure there is no lint hiding behind the bobbin case.
Posted on Jun 01, 2010
Testimonial: "Thank you! I'll try it!"
Bobbin latch on Singer Touch and Sew model 626 won't seat properly. Therefore plate covering bobbin case will not slide back into place.
Have you had the bobbin case out? If so, remove it again and replace carefully.Or contact manufacturer .
Apr 29, 2017 | Singer Sewing Machines
Bobbin case keeps popping out
Hallo Rhonda
Pls chk your bobbin locking at fixing shaft grew or not. on bobbin a sliding locking plate locks at shaft. while keeping in case chk that is loked by pulling. if it dosent lock , change bobbin with spare one.
Jul 16, 2014 | White Sewing 2037 Mechanical Sewing...
Needle plate on Pfaff 1471 - removed to clean, when I try to put it back on it keeps popping back up. Is there supposed to be a
check to make sure the bobbin is seated correctly in the bobbin case & then try the bobbin cover, it's suppose to click or snap in
Mar 30, 2012 | PfaFF Sewing Machines
Singer 2263 instruction manual does not show where to lubricate or how to adjust the hook which keep jamming
First make sure that the needle is fully up. Then you need to open the hinged front cover and unscrew the needle plate screws. Remove the bobbin. Brush out any lint now. Remove the bobbin case. Then snap the hook retaining arms outwards. Remove the hook cover and hook. Put no more than 2 drops of sewing machine oil on the the case (center right hand side). Then turn the hand wheel until the hook race is in the left position. Replace the hook and then the hook cover. Snap the hook retaining arms back into position. Replace the bobbin case and bobbin. Then replace the stitch plate.
Test the machine on a piece of waste fabric. If the hook keeps jamming, take the machine in for maintenance. The parts that may need to be replaced are the race or the shuttle hook. However without seeing the unit I do not know if there is not another problem. Some parts for the 2263 are available here: http://www.sewingpartsonline.com/singer-2263-sewing-machine-parts.aspx .
Singer has a second manual available with the oiling instructions for the 2263 here: http://www.singerco.com/uploads/download/1213_oiling-2263.pdf . See the diagrams on this page for where things line up. The rest of the instruction manual is also online here: http://www.singerco.com/uploads/download/1180_2263%28eng_spa_fre%29.pdf .
I hope this helps.
Oct 08, 2011 | Singer 2263 Mechanical Sewing Machine
Bobbin casing
Wise not to use it until you have the proper slide plate
Jul 13, 2010 | Euro-Pro 9105 Computerized Sewing Machine
I have a Singer model 4562 T sewing machine, and threading the bobbin, the bobbin case just kind of popped out. I've tried just sliding it back in, but no matter which way I put it in it doesn't seem to...
The bobbin case is designed to be removed for cleaning. Take off the needle plate if it is still on the sewing machine. Make sure that the needle and presser foot are fully up. Guide the forked end of the bobbin case under the feed (more or less centered). Then pull the bobbin case under the rim of the position plate. Pull on the side opposite the forked end of the bobbin case. With a small screw driver, turn the lever (at about 10 o'clock on a 12-hour analog clock) towards you. This will lock the bobbin case into place. Make sure that the bobbin case isn't locked too tightly. It still needs to move slightly as the bobbin turns and the needle comes through that plate.
Replace the needle plate and lock it down. Then insert the bobbin and close the slide plate. The manual shows the procedure to remove and replace the bobbin case on the 4562 on page 39. Singer has the manual on the support page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/435_5_8_10_16_22_dial.pdf .
I hope this helps.
(I hope that the locking lever hasn't broken. That may require a service person to solve the problem. I'm not entirely sure where that lever is connected to the machine. Some Singer part diagrams are here: http://www.singerco.com/support/replacement-parts-chart . The 4562 may use the same diagram as the 4572, http://parts.singerco.com/CPpartCharts/4_4999/4572.pdf .)
Jul 01, 2017 | Singer Sewing Machines
METAL PLATE COVERING BOBBIN WON'T STAY DOWN
Take it apart again and compare the original screw with the one you substituted. If they are not the same size, you will need to get one that matches the original.
Re-place the needle plate and when firmly in place, put the screws back in.
Mar 03, 2010 | Sewing Machines
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. I cleaned the bobbin case, but now it won't sew at all; the case keeps...
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
Jan 17, 2010 | Singer Inspiration 4210 Mechanical Sewing...
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. What is causing this? Is the bobbin case in wrong? How is it supposed...
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
Nov 14, 2009 | Singer Inspiration 4210 Mechanical Sewing...
Singer 2639 Logo
241 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
