Question about Car Audio & Video
I have a 2005 Chevrolet Suburban that when you start to accelerate it has a high pitch whining sound coming through the speakers. The faster you go the louder it gets. What is the cause ?
    Scholar:
  • 84 Answers
You have a ground loup, or an improper ground. Or if you have your speakers on an amplifier your rca cables are ran on the same side as your power wire to the back. I suggest checking the ground on your source unit. That is alternator wine and is definately fixable shouldn't be too much hassle
Posted on May 31, 2010
High pitched whine while accelerating
remove the belt and start the engine ..IF THE NOISE disappear it might be idler bearings that driven by belt but if the noise still there check the pcv valve..
Sep 24, 2013 | Toyota Tacoma Cars & Trucks
High pitch noise when accelerating
worn belt, or the cv axels. drive in a tight circle each direction and listen for for a clicking sound. if you hear one then your cv axels need to be replaced
Mar 24, 2013 | 2005 Mitsubishi Lancer
Whining noise on 2002 chevy tracker, comes and goes
Could be your alternator or a bad idler pulley. Is the transmission good? It may be the tranny or your differential whining.
Feb 18, 2013 | 2002 Chevrolet Tracker
Just replaced a dead battery with a brand new one. Tried starting it and it makes a high pitch whining sound and wont start. Any suggestions of what the problem is? Does it need to sit to charge the...
The basics, your battery is used to provide power to the starter. Once the engine is running the alternator then provides current to recharge the battery and run all of your electrical components. so I would suspect the starter is not working to start the engine.
Feb 16, 2011 | Chevrolet Classic Cars & Trucks
2000 Suburban: High-Pitched electronic whine near rear of surburb...
That "whine" is the fuel pump inside the tank. This usually gets louder at or below 1/4 tank. Expect the fuel pump to go out soon.
May 16, 2010 | 2000 Chevrolet Suburban
Same problem: a high pitch whine after extended driving
Sounds like a dry/failing bearing or power steering pump noise. You first need to try to track down where the noise is originating, and the most likely place is at the front of the engine.
I would start by listening with the hood up while parked with the engine running and the noise present, and seeing if it is coming from there. If so, the most likely cause is something connected to the belt - e.g. AC compressor clutch, tensioner, power steering pump, or generator. Can also be caused by the belt just slipping (warn out belt, tensioner not working properly).
Mar 31, 2017 | 2001 Chevrolet Venture
High pitched electronic/dentist drill sound when accelerating.
Probably the front differential, your probably hearing the famous differential gear whine. Change the oil, put Lucas for gears in it. You can get a hand operated oil pump to **** it out through the dip stick if it has one. Then fill it with the recommended amount.
May 06, 2009 | 2007 Nissan Xterra Off Road
High Pitch whine during acceleration
Hi Pullerwife,
I have a few suggestions for you,
First of all, check your air filter, make sure its clean, not clogged, and doesn't need to be changed.
I don't know how handy you are, but if you are fairly handy, check the idler pulley bearings, if your not, have a shop check it out, as a last resort.
Power steering pump/fluid being low is also a possibility, but thats usually more of a lower pitched whine then what you describe.
You say once the vehicle is warmed up, the whining stops. Does Weather seem to be a factor as well?
Hope I've helped, and don't forget to rate.
Lazaruselite
Feb 25, 2009 | 2005 Chrysler Town & Country
HOwling noise from 99 Suburban 4X4
might be one of your catalytic converters clogging up. usually happens after engine has been running for a time? mostly heard when you let off the gas pedal? does the noise appear to be coming from the transfer case area? i thought i was having tranny problems, but turned out to be one of the catalytic converters. whew....
Oct 18, 2008 | 2002 Chevrolet Suburban
Car Audio & Video Logo
150 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
