Question about Hammer Factory-Reconditioned Milwaukee 1/2" Single Speed Drill w/ Case 5381-82
Jackhammer drill with false contact
I have a jackhammer drill thatt start having false contact in the trigger, first in the reverse mode and then in both directions. I want to know how to fix it?
  • 43,501 Answers
Replace the switch... it is bad...
heatman101
Posted on Aug 27, 2010
Why cant i get my drill bit in my hammer drill?
the end either pulls out or pushes in to insert and remove drill bit
Dec 16, 2015 | Hitachi DH50MR Jackhammer
Electric Milwaukee drill locked in reverse
This is a common issue with drills, you can resolve the issue by purchasing a new trigger switch and installing it. It is a very simple task. all you will need is a screwdriver and about 10 minutes.
Mar 09, 2011 | Milwaukee Electric Drill 1/2in. Chuck...
HI,my Hitachi 18v DV18DL Hammer drill will only run in reverse,any help?TKS Rob
the triger contacts could be fouled. clean the contacts if it doesn"t work you can order a new trigger assembly from hitachi---ACE hardware may even carry this
Dec 30, 2010 | Hitachi Dv18dl 1/2 18v Hammer...
How to use hand drills?
Use of both is the same:
- loosen "chuck" (part where bit is installed).
- insert bit (hand tighen chuck so that bit is secured)
- tighten chuck securely with chuck tool, or by holding rotating chuck with hand and pulling trigger (GENTLY or you will shave off skin!)
- put drill in forward or reverse mode and pull trigger to inser or remove screw / drill hole.
ensure that battery is charged on cordless drilll.
squeeze connectors to remove and place in charger when battery is too low to operate drill.
Apr 27, 2010 | Bosch 14.4V Brute Tough Drill Kit
How do I attach the drill bit to the chuck on a ss 120 drill
Well I couldn't find a pix of your drill so I will guess that it is a typical drill. You seem to be asking a very basic question so I will start will all the basic info I can think of.
First you have to know where the power trigger is to make it go.
2nd you have to know where the forward and reverse switch is.
Now with the switch in the forward position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the center Jaws should close up and come out of the chuck.
Now with the switch in the reverse position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the cetner Jaws should open up and go into the chuck to a maximum point
Open the jaws enough to put the drill in the jaws then put the switch in the forward position. Put the drill in the chuck, sqeeze the trigger to make it go, and hold the chuck so the jaws close on the drill. All while keeping the drill from falling out of the chuck.
When it closes on the drill and the drill is in straight then hold the chuck as tight as you can while squeezing the trigger to make the jaws close very tightly on the drill. If you have very tender hands you might want to use gloves.
To get the drill out put the switch in reverse, hold the chuck very tightly, and squeeze the trigger to open the jaws off of the drill.
Nov 28, 2009 | Black & Decker Drills
Drill starts and stops like there is something loose on the inside
This is typically caused by one of two things. Worn brushes or a bad switch. How old is drill and has it been used a lot? If the brushes are worn/bad they will need replacing. If the switch (trigger) is bad it can sometimes be fixed by spraying an electronic contact cleaner in it. This cleaner can be purchased at Radio Shack. I have also had good success using WD40. Spray the switch down good (power removed) and manually operate it a few times, wipe it clean, plug it in and try it again.
Nov 16, 2009 | Black & Decker 3/8" Variable Speed...
How far do you put a bit in to know it's placed correctly. I'm trying to surprise my husband by removing some kitchen cabinets, but I'm not sure I put the bit in right and I don't know how to make the...
Find the reverse switch near the trigger. Press one direction for forward, in the middle is a trigger lock and the other direction is reverse. Dont surprize yourself and have the cabinet fall on you.
If you have short bits, put about 1/2 of it into the chuck. If you have long bits (about 2 inches long), put about 1/2 inch of it into the chuck.
Be aware that when the drill runs in reverse, the chuck tends to loosen and when that happens, your bit will fall out.
If Hubby has a bit holder, I'd suggest you use that and place the bit into the bit holder. Makes for a better reach.
Good luck on your project.
Oct 18, 2009 | kawasaki 19.2v 20 Pc Cordless Drill Set
Panasonic EY7540 impact driver. Does not go into reverse on 1st
The forward/ reverse switch is hanging up and the rotation of the drill is switching it, then it changes direction. The switch needs a little TLC and a good cleaning. Blow it out.
Sep 26, 2009 | Panasonic Cordless 12V Compact Impact...
I am the owner of a TE 905 Hilti Jackhammer, Serial No. 234137, I need to purchase replacement brushes and a 14" long flat chisel bit for the Hilti Jackhammer
Did you contact the place you purchased it from? If you still have the paperwork that came with it might have the replacement part #s in one of the flyers. Google the make and model.
May 14, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Hammer Factory-Reconditioned Milwaukee 1/2" Single Speed  Drill w/ Case 5381-82 Logo
78 people viewed this question
Top Hammer Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
shall39
Level 1 Expert
Are you a Hammer Drill Expert? Answer questions, earn points and help others
