Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Hoover SteamVac Widepath serial #F6026-900 /10757
I've lost my owners manual and would like to clean the **** that sucks up the water. It's got a bunch of dog hair stuck there. Is there an easy way to take thar part off?
  • petlover52 May 28, 2008
    The suction does not seem to be working. I think it may be clogged with dog and cat hair. I can't figure out how to take it apart to clean it.
Http://www.hoover.com/pdfs/manuals/F6039900.pdf
You can get the manual that covers your model and other F60**-900 models here
Posted on Jul 21, 2008
Hose leaks solution, need to replace, where can I get this part?
Posted on Aug 02, 2009
  • 3 Answers
Lift up on the back section where the recovery tank sets over the hole and lift it off.
Get a manual here http://www.vacuumcleanershop.com/hvrmdlf7205900.htm#B2
Posted on Jul 01, 2008
Attach the hose to a "hoover f7425 900 steamvac v2 widepath
click here> http://hoover.com/file/670/ for the manual it will give you full instructions how to attach the hose
Sep 25, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
http://www.hoover.com/pdfs/manuals/F7452900.pdf Heres a link to the manual if you dont have one, Ive emailed them and they gave me the same solutions that are on page 17. ? Make sure tank is securely locked in position ? Clean water tank or detergent container empty ? Refill container according to instructions for surface being cleaned ? Recovery tank lid not on correctly ? Make sure lid is firmly in place ? Valve cap clogged ? Remove and clean valve cap (see following instructions) 1. Remove clean water tank. 2. Turn valve cap (A) counterclockwise and remove. Soak valve cap in warm water for at least 15 minutes. Wipe cap dry. 3. Align slots (B) on cap with tabs (C) in opening. Turn cap clockwise to tighten.
Sep 17, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Vac not sucking up water
its supposed to, it means you need to dump out the tank. Its a safety feature that keeps the water out of the motor. if its lifting up due to foaming, than try using the original brand shampoo
Jul 13, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
We need the OPERRATING MANUAL for Hoover Steamvac 6020-900
download the manual for hoover F5810 at hoover.com. it's the same for your model.
Jan 20, 2009 | Hoover F6020-900 SteamVac Upright Vacuum
Need help!!!!!
Need help!!!!!
I read the manual and tried my new Hoover, the brushes spin, but the waters not going to the bottom tank, what does that mean and what can i do?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You could have a bad water release valve on your water tank of which holds the water, the trigger assm might not be connected, bent or broken. Check the trouble shooting owners manual --- also there are hoses that could be crimped or bent, or clogged or not connected, but it is my guess it is the water release valve. Try to back track the water from the holding tank and test all the valves on the system and you might find the problem by the process of elimination. Feel free to contact you local vacuum cleaner dealer in the yellow pages or contact the Hoover Co @ the information listed below:
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Apr 22, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover widepath steamvac
One cause is the filter in the dirty water tank lid is pushed up too high, it needs to have a gap of 1/4 in or so. So check it, if it is up all the way, pull it down some.
Jan 15, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steamvac Widepath 6500 leaks
You didn't give your model number, but if this is a V2, you may have a crack in the tank, alot of times it is underneath the seal on the bottom. Or the plunger at the bottom of the tank is stuck open or missing.
Dec 02, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes are not moving
You should be able to get a manual from Hoover.
Oct 21, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
808 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
