Have Directv and I can shut down the box but the lcd tv will go on and off and continue till i hit the volume button - it will stop the switching back and forth. I can only shut down manually. TV is plugged into wall and not into box.
SOURCE: TV shuts down
In response to the "Guest" post on 12/21/07, first, thanks for your reply. Yes, I agree that it's potentially a thermal issue, given that the longer it's on, the more often it happens. However, I have never gotten temperature warning lights to come on in relation to this issue. (Maybe the temperature sensor is broken.) I have a new bulb coming tomorrow, so I can see if that fixes things. If not, the next thing will be for me to pull off the back panel and vaccuum everything out to see if the heat sinks have gotten dirty (and therefore, less effective).
HP said they would allow me to return the bulb within 21 days, so it doesn't cost me anything to try the new bulb.
I'll put up another post with my results later.
- Paul
SOURCE: HDTV
Shouldn't have to, but HD through the wall connector may be an issue if you are wanting that. I don't know for sure. Almost all tv's made in the last 1 year - 2 years have digital tuners built in
SOURCE: My tv changes channels and volume.
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
SOURCE: Hp TV wont stay on cable setting
contact us for legal action agaist HP for this model HP tv. They sold this TV with known defects. [email protected]
SOURCE: same problem as don5625.my moxi box will not
Is this the style of Moxi remote that you have?
If so try these steps to find your TV
1. Turn on the power to your TV.
2. Press and hold down the MOXI and OK buttons.at the same time until the LED at the top blinks twice.
3. Press the numbers 9910 on the remote and the led should blink twice again.
4. Press the mute button. If the TV mutes then press OK to lock in the code. If the TV does not mute press the up arrow once then press mute and continue to press the up arrow once then press mute until the TV mutes once the TV mutes press the OK button to lock in the code.
*** Note this may take a couple minutes of trying to cycle through the code list to find which one will work with your TV *****
Good Luck...
